Print at Oct 6, 2026, 9:36:45 AM
Posted by Bobby_21 at Aug 9, 2024, 11:51:52 PM
Roof view from inside
Hi, I’m a newbie and have just started using the generate roof plugin. When trying to draw a bungalow, should I see the inside of the roof from in the building? This is what I am trying to do.
Posted by Keet at Aug 10, 2024, 9:14:03 AM
Re: Roof view from inside
Right click in the 3Dview and select 'Virtual visit'. That gives you a camera you can position to view the inside of the roof.
Posted by Bobby_21 at Aug 10, 2024, 11:24:17 AM
Thank for the post Keet.
If I do this i just see blue above me. The only way I can see the roof is if I change from level 1-dim to roof-gen but then I can only see the whole building if i place the camera outside, from inside i just see the roof structure, not the actual room.
Posted by Puybaret at Aug 10, 2024, 11:59:41 AM
Maybe you didn’t select the 3D View > Display all levels menu item.
Posted by Bobby_21 at Aug 10, 2024, 3:12:15 PM
Thank you very much Puybaret, that did it.
