Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Export plan to image plugin creating empty png |
| Print at Sep 21, 2026, 8:13:18 PM | |
| Posted by DavyR at Jul 31, 2024, 7:45:01 PM |
Export plan to image plugin creating empty png I am on version 7.4.1 of Sweet Home on a Mac M1, and have installed ver 1.0.2 of the Export Plan to Image plugin ExportPlanImage-1.0.2.sh3p. When used, the plugin creates a zero byte png file in the destination folder (/Users/m1/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data) and a .tmp file in the /Data/tmp folder. Manually changing the tmp file extension to .png results in a fully functional image. Can anyone shed light on how I can fix this? |
| Posted by Puybaret at Aug 1, 2024, 9:51:53 AM |
Re: Export plan to image plugin creating empty png I tried again ExportPlanImage-1.0.2.sh3p plug-in with Sweet Home 3D 7.4.1 on a MacBook Air M1 and I didn't encounter any issue. Did you get any error message? How large is the exported file found in tmp folder? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by DavyR at Aug 1, 2024, 11:05:21 AM |
Re: Export plan to image plugin creating empty png No error message. I typically export at 2000px and the file in the tmp folder is around 400kb. In case its relevant I'm on Sonoma 14.5, and have the following plugins installed: - Change color - Export plan to Image Multiplier Pan in 3d view Plan rotator Plugins manager SVG tuner Staircase generator Wirings de.starrunner.sweethome |
| Posted by PeterW at Apr 25, 2025, 9:11:54 PM |
Re: Export plan to image plugin creating empty png I just ran into this bug on a fairly large image. Reducing the image size from 10,000 pix down to under 9,000 fixed it in my case, although for some reason the .png files save with black backgrounds when opened, plain in the preview, doesn't happen all the time, and only with png not jpg |
Current timezone is GMT Sep 21, 2026, 8:13:18 PM |
