Print at Sep 23, 2026, 8:32:35 PM View all posts in this thread on one page
Posted by il_drate at Jul 19, 2024, 11:52:00 AM
tools no longer selectable
Hello there,
I'm having a strange issue on a single project with the online version of Sweet Home 3d: some tools on the bar are no longer selectable (create measure, create room, create walls, etc). Also I can't add fornitures no more.
As I said, that is happening just on a single project, no issues in others. Am I doing something wrong?
Posted by Puybaret at Jul 20, 2024, 10:24:08 AM
Re: tools no longer selectable
Did you try to reload the page?
Posted by il_drate at Jul 20, 2024, 1:04:09 PM
yes, many times but nothing change.
In fact, I can't edit the project anymore. I also tried to duplicate it, but same result.
Posted by Keet at Jul 20, 2024, 2:04:09 PM
I don't know if this is related to the problem you have: Make sure your current/active level is visible otherwise you can't edit it.
Posted by ChecMark at Apr 23, 2026, 1:14:22 AM
I'm sorry to butt in on this post but I'm really struggling trying to design the kitchen. I can't even find fridges. Many videos say to click on the "Tools" then "Cabinet Maker" but I have no "Tools" in my menu and can't find the "Cabinet Maker" anywhere. Appreciate any help.
Posted by Keet at Apr 23, 2026, 6:26:00 AM
The "Tools" menu item is a default menu item and should be available in a correctly installed Sweet Home 3D.
The Cabinet Maker is a plugin that must be installed before you see it in the Tools menu.
First install the Plugins Manager which makes is much easier to install/remove other plugins. Using the plugins manager you can install the Cabinet Maker. Make sure to also install the Advanced Edit plugin, it's a must-have.
If you decide to use existing 3D models you can search for them on the internet. On my site dodecagon.nl I offer two kitchen cabinets libraries and a kitchen appliances library.
Posted by dorin at Apr 23, 2026, 8:54:06 PM
Tools menu IT IS NOT a default menu item.
It appear only if you install at least a plugin which programed it(Cabinet maker, Roof generator, Advanced editing etc).
Posted by Keet at Apr 23, 2026, 9:01:28 PM
I didn't know that! I am so used to having the Tools menu and I don't remember ever seeing it without, even with a new install. Probably because the plugins directory is still there from the previous install. After 18 years using Sweet Home 3D you can still learn something new smile
Posted by ChecMark at Apr 24, 2026, 10:17:55 PM
A very helpful gentleman managed to allow me to add the Cabinet Maker. I was thrilled and spent an hour redesigning a base cabinet to perfection, only to end up clicking on "Okay" and got nothing! No idea what I am doing wrong.
