Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to remove curves that indicate which way the door swings? |
| Print at Sep 21, 2026, 10:51:00 PM | |
| Posted by test999 at Jun 25, 2024, 12:36:20 PM |
How to remove curves that indicate which way the door swings? Is there a way to remove a curve that indicates which way the door opens? thank you |
| Posted by Daniels118 at Jun 25, 2024, 6:50:56 PM |
Re: How to remove curves that indicate which way the door swings? Yes, the easier method is to export the door and import it as a new door. |
| Posted by Keet at Jun 25, 2024, 8:02:01 PM |
Re: How to remove curves that indicate which way the door swings? Yes, the easier method is to export the door and import it as a new door. Definitely the easiest and quickest way.For a beginner here's why: The sashes (the curves that indicate which way a door or window opens) are defined in a Furniture Library as additional properties for a model. By exporting and importing you get the same door but without the additional properties from the Furniture library. Note that if more extra properties were defined for the door you will loose those too. For example a distance indication from the wall to extend a border outside the wall, a custom cutout shape, or the default elevation. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by AaronRogers at Jul 12, 2024, 11:35:55 AM |
Re: How to remove curves that indicate which way the door swings? Thanks, I will try it and if I face any issue, I will ask by starting my own thread. |
Current timezone is GMT Sep 21, 2026, 10:51:00 PM |
