Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Resize entire project |
| Print at Aug 19, 2026, 12:08:44 PM | View all posts in this thread on one page |
| Posted by lvmnky at May 27, 2024, 8:30:03 AM |
Resize entire projectHi all, I have been using SweetHome3d to replicate my new house and work on some renovations. When I replicated the floorplan I didn't notice that CM was being used as the unit and I scaled everything in MM. Now I am having issues when adding windows, doors etc. Is there a way to select the entire project and pretty much divide it by 10 so to convert all measures from MM to CM? I have installed Advanced Editor and I see the resize option, when I do use it though the walls are all stack up on each other, I am not sure if I am doing something wrong or is just not supposed to be used for this purpose. All help is greatly appreciated |
| Posted by hansmex at May 27, 2024, 9:49:26 AM |
Re: Resize entire project It's hard to say what you have to do: so many variables, and not much info. Indeed, the AdvancedEditor is the tool to use. WHAT you have to change depends on what is incorrect. Suggestion: make a backup of your plans and work on that file to see what needs to be done. 1 - check height of levels and thickness of floors 2 - check height of walls 3 - check length of walls 4 - check size of furniture (doors & windows are furniture) Where it says "check" you should read "check and if necessary correct by multiplying or dividing by 10". When changing furniture make sure you put a checkmark in "Keep proportions". ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by lvmnky at May 27, 2024, 10:13:42 AM |
Re: Resize entire project Thanks for the reply, I tried again and realized that after executing only the thickness of the wall wasn't resized, so I just manually changed the value of each wall and it all was correctly positioned after that, thank you |
Current timezone is GMT Aug 19, 2026, 12:08:44 PM |
