Print at Sep 14, 2026, 7:35:24 PM
Posted by GiacomoFR at May 17, 2024, 6:13:19 PM
SH3D totally reset
Hello,
I use SH3D from many many years and for the second time in my life (the first ten years ago) I open the program and all the textures and files 3d are gone...
the software appears as if it had just been installed..
I use windows 10pro.
Has anyone had the same problem as me?...and above all you managed to restore?
thanks
Posted by Puybaret at May 17, 2024, 6:31:01 PM
Re: SH3D totally reset
Could you check the content of the folder C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D (where user is you login)?
It should contain a file named preferences.xml and many files with a .pref extension.
Posted by GiacomoFR at May 17, 2024, 6:49:29 PM
thank you very much for the quick reply, inside the roaming folder I don't have a subfolder for sweethome...
the preferences.xml file is contained in the users/myname/eteks/sweethome3d folder
Posted by GiacomoFR at May 17, 2024, 6:56:55 PM
it's embarrassing to say the least... basically it's as initialized, it also offers me suggestions when I click on a new button... how can I go back to the old SH3D?
Posted by Puybaret at May 17, 2024, 7:28:27 PM
If that folder is empty, I fear that all the imported stuff is lost, but don’t worry for your existing plans, they’ll still work because they contain all the data they need, imported or not.
Posted by GiacomoFR at May 17, 2024, 7:34:20 PM
yes, the projects already made are always visible, but I had hundreds of textures and 3D files that I used for work and now I will have to import them again.
I ask for one last piece of advice, is there a way to export a 3D file or a texture from a room already made?
Posted by Puybaret at May 17, 2024, 7:51:40 PM
No, there’s no such tool. Sorry.
In the future, I would recommend to use the the plug-ins ExportToSH3F and ExportToSH3T to back up your imported models and textures, even if the bug you reported is really rare.
Would you remember anything special that could have happened around the moment of this bug?
Posted by GiacomoFR at May 17, 2024, 8:05:32 PM
thanks for the advice, no honestly no, the PC updated last night and from today... blackout
Posted by brisseauc at May 17, 2024, 8:36:40 PM
Je ne comprends pas l'anglais
Posted by Puybaret at May 17, 2024, 8:59:57 PM
Apprenez à utiliser les outils comme Google Translate !
Posted by Keet at May 17, 2024, 9:13:45 PM
Je ne comprends pas le français et j'utilise DeepL.com pour traduire en anglais. smile
