Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to make transparent textures |
| Print at Aug 5, 2026, 9:40:05 PM | |
| Posted by hansmex at Feb 2, 2010, 2:20:48 PM |
How to make transparent textures Hello all :-) Does anyone have a suggestion how you can make semi-transparent textures? I can think of several scenarios: - Partially transparent walls: here I want to apply a texture to a wall. Where the GIF or PNG image is transparent, the wall should be transparent as well. - Partially transparent objects: let's say I create a cube with a texture applied to one face. Where the image is transparent the cube should be transparent as well. These images help explain what I want to achieve. I tried some variations, but sofar without success. Hopefully someone has good suggestions. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by peefy at Sep 11, 2024, 6:50:49 AM |
Re: How to make transparent textures I am interested in how to do this as well. Anybody any suggestions? Thanks! |
| Posted by Keet at Sep 11, 2024, 9:15:08 AM |
Re: How to make transparent textures A basic search would give you many answers to accomplish this. Depending on your system you can use one of the suggested solutions here: https://www.makeuseof.com/how-to-make-background-transparent/ If you only have a single image you want to convert there are many online sites where you can do easily this for free. I always use GIMP. Basicly you add and aphachannel to the image and set the transparency to a selected color. The link I gave also explains how to remove a background for an image using different graphics programs. Remember to save in a format that supports transparency, for example PNG. (JPG doesn't support transparency.) ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by captaincook at Sep 11, 2024, 2:29:44 PM |
Re: How to make transparent textures Bonjour. J'ai aussi découvert par hasard une possibilité de Power Point (pour ceux qui l'utilisent) et c'est très pratique. Regardez la vidéo suivante. https://youtu.be/zvEbOjns9Tc J'ai testé et ça marche très bien. Adobe Express, une application en ligne gratuite, est aussi très intéressante et très simple à utiliser. Image initiale : ![]() Image produite par Adobe Express : ![]() L'arrière plan, qui apparait en blanc sur l'image, est en fait transparent. Texture obtenue et appliquée sur la face avant d'un cube de 100*100*1 dans SWH: ![]() Image finale en 3D dans SWH: ![]() |
Current timezone is GMT Aug 5, 2026, 9:40:05 PM |
