Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can i import images ? |
| Print at Sep 13, 2026, 7:08:01 PM | |
| Posted by zazay at Apr 29, 2024, 7:04:43 PM |
Can i import images ?Hi Can i import images to my 3D plan (i'm not talking about the background image) ?? if the answer is yes, then how ? ![]() |
| Posted by Puybaret at Apr 29, 2024, 7:49:11 PM |
Re: Can i import images ? What are you trying to achieve? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at Apr 29, 2024, 8:00:34 PM |
Re: Can i import images ? Every texture is an image. When you apply a texture to a surface you effectively import an image to show on that surface. But the answer to Emmanuel's question "What are you trying to achieve?" can determine if applying a texture can solve your problem. One very interesting topic in this forum is from GaudiGalopin3324. I once gave him a simple idea and test model to integrate photo's as replacement for 3D models and he took a run with it. He made some amazing progress in integrating photo's in his Sweet Home 3D projects. Start reading here where I gave him the first model and read about the great results he got with lots of experimenting: https://sweethome3d.com/support/forum/viewthread_thread,12648_offset,60#61022 ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 13, 2026, 7:08:01 PM |
