Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to show area between walls ? |
| Print at Sep 15, 2026, 11:16:59 AM | |
| Posted by Micke2nd at Apr 23, 2024, 9:00:17 AM |
How to show area between walls ?Hi, when you create rooms, you can have their area displayed. see below in the screenshot: In the following screenshot you can see that area can also be displayed in the mode with walls, but how? I used the forum search but it only returned posts like: Area calculation and auto dimensions for 2D thank you in advance Micke |
| Posted by dorin at Apr 23, 2024, 5:35:20 PM |
Re: How to show area between walls ? but how? Creating a room! After you create a closed space with walls (preferably connected), select room tool from tools bar and double click inside the space formed by walls. A new room with their surface will appear. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Keet at Apr 23, 2024, 5:35:48 PM |
Re: How to show area between walls ? I suspect that you are trying to find where the area display is switched on/off in the modify walls dialog but the room is a separate object with its own modify dialog. Double click on the room and you get the modify room dialog. At the top right you see a checkbox where you can switch the display for the area on and off. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Micke2nd at Apr 23, 2024, 9:17:46 PM |
Re: How to show area between walls ? After you create a closed space with walls (preferably connected), select room tool from tools bar and double click inside the space formed by walls. aaaaah , thank you ! |
Current timezone is GMT Sep 15, 2026, 11:16:59 AM |
