Print at Aug 6, 2026, 12:28:24 AM
Posted by dweep62 at Feb 1, 2010, 11:10:53 AM
Can't view the background images
After following every steps like choosing image,definning scale and origin no background images are visible. Modify of background images can be done but the background images are missing.Plz help me to find out the problem.
Dweep.
Posted by Puybaret at Feb 1, 2010, 2:14:52 PM
Re: Can't view the background images
At the second step, did you enter the length of the drawn line in real life, meaning a value greater than 100 if unit is still centimeter?
Sometime some users enter the length measured on the screen on the paper, and the resulting scale is too small.
Posted by dweep62 at Feb 2, 2010, 11:23:59 AM
Thanks.Stating below what I have posted:
In second step,the length of the drawn line(inch)-336.
In third step,X(inch)-413.386, Y(inch)-584.843, and finished it,
Still no images appeared.
What shall I do now.......
Dweep.
Posted by hansmex at Feb 2, 2010, 11:56:20 AM
Dweep:
Why not try this: save your file using Save --> Save and Compress and post it online (e.g. at www.mediafire.com). Then post a link on this forum so we can inspect your file.
Posted by dweep62 at Feb 4, 2010, 8:47:33 AM
Thanks for your active support. I have uploaded my plan DweepPl81.rar in www.mediafire.com. The link is http://www.mediafire.com/?d0gejdym0tt.
Hope this may help you to inspect my problem.
Thanks again,
Dweep.
Email: [email protected].
Posted by Puybaret at Feb 4, 2010, 9:27:03 AM
Once I understood your plan indicated distances in millimeter, I had no problem creating it...
Posted by hansmex at Feb 4, 2010, 1:08:51 PM
Dweep & Emmanuel:
Dweep: If you follow this link you can download an "empty" file with your drawing set as background image.
Emmanuel: There seems to be a bug in the latest beta. When drawing a wall it isn't possible to edit it. I found out when importing Dweep's PNG as a background image. I then checked with an older design of my own. I even restarted the computer but couldn't edit the walls anymore.
I then tried to revert to an older beta, but without succes. I hope you have a solution :-)
Posted by Puybaret at Feb 4, 2010, 2:00:18 PM
Hans, I just tried in the current Beta to modify walls with Plan > Modify walls... menu item, its shortcut or with the mouse in Selection mode, and I had no problem.
Could you describe the exact sequence of the bug you found?
Posted by hansmex at Feb 4, 2010, 2:57:40 PM
Emmanuel:
After opening v2.3b5 I draw a straight wall, then do a right-click to edit its features. No window opens. I then try Plan --> Modify walls and no window opens.
I close v2.3b5.
I open it again and load one of the Brad Pitt houses. The program crashes while loading. I repeat the procedure and get another crash.
I then try the Sosnowksi house (see gallery for all these houses) and again the program crashes.
I shall now restart my PC and see if things are better.
To be followed...
Posted by hansmex at Feb 4, 2010, 3:44:00 PM
Emmanuel:
Part 2: I restarted my PC and only started my chat-client, NO Firefox, to have the system as clean as possible.
I started v2.3b5 and drew a wall. It was possible to edit it. I opened an existing file, and no problem editing the walls. I then clsed SH3D again.
I restarted SH3D, and in File --> Preferences I set the measurement to millimeters. I then tried to import an image as a background, but that didn't work.
It seems as if the "bug" is triggered by the mm-setting. Maybe it is in some way connected with the three digit thing, or the max size = 9999 thing??
When I close SH3D and restart again, change the measurement to meters, I can import a background image without problems.
