Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: levels list pane |
| Print at Aug 21, 2026, 8:59:13 AM | |
| Posted by mirakels at Apr 9, 2024, 9:30:07 AM |
levels list pane Maybe it is my windows setup, but from the list of levels in the top pane it is hard to see which one is currently in view. I would even say it is impossible to see as all tabs in it seem have the same color. Is it possible to better highlight the active level? Also when right clicking on the levels pane I would expect to just get the popup menu window, but it also causes to make the level the cursor happens to be on active (i.e. the drawing pane changes to that level). (I saw/see this on version 7.2 and 7.3) Thanks |
| Posted by Puybaret at Apr 10, 2024, 7:07:53 PM |
Re: levels list pane You're right, the difference between the selected level tab and the other tabs is actually less visible under Windows 11 (right in the following image) than under Windows 10 (left). I note this and will try to improve it in a future version. when right clicking on the levels pane I would expect to just get the popup menu window, but it also causes to make the level the cursor happens to be on active This right click behaves quite weirdly. Sometimes it selects a tab, sometimes not. I will try to fix that too.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 21, 2026, 8:59:13 AM |
