Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: How do I get rid of the white outline around the photos on the boxes in YafaRay? |
| Print at Sep 26, 2026, 10:29:54 PM |
| Posted by GaudiGalopin3324 at Mar 17, 2024, 12:30:25 AM |
Re: How do I get rid of the white outline around the photos on the boxes in YafaRay? I've been on various forums. Yes, Photoshop has this problem. There is a two-pixel-wide layer of translucent pixels along the border of the image on a transparent background. They give a white thin stripe in a high-quality engine like Yafaray. We need to remove these translucent pixels and that's it. Until I learned all the techniques. I did it very roughly, enlarged the original photo to a gigantic size of 10,000 pixels. And I cleaned the background with a hard eraser on such a small-pixel field. It works with a creak, but of course you need to learn simpler techniques. |
| Posted by Keet at Mar 17, 2024, 7:53:36 AM |
Re: How do I get rid of the white outline around the photos on the boxes in YafaRay? Weird that Photoshop adds a two pixel border. It's probably meant as a transition border but it shouldn't be added without a setting to do so. Maybe try GIMP instead of Photoshop. Most important: it would be great if you could remove that border and solve the white line problem. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Daniels118 at Mar 17, 2024, 10:09:57 AM |
Re: How do I get rid of the white outline around the photos on the boxes in YafaRay? It's not a problem in Photoshop, it's called antialiasing, it is required to get soft edges on transparent pictures. The problem could be that YafaRay doesn't handle half-transparent pixels correctly. You could simply apply a threshold on the alpha layer to get rid of translucent pixels, see here: https://graphicdesign.stackexchange.com/quest...y-of-a-smart-object-layer PS. if you have the original picture, just turn off antialiasing when cutting the background. |
| Posted by GaudiGalopin3324 at Mar 17, 2024, 11:06:06 AM |
Re: How do I get rid of the white outline around the photos on the boxes in YafaRay? Thank you very much!! I will try. |
Current timezone is GMT Sep 26, 2026, 10:29:54 PM |
