Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Video render works first time only |
| Print at Aug 26, 2026, 10:51:42 AM |
| Posted by lubimaer at Mar 11, 2024, 9:42:21 PM |
Video render works first time only Hi Folks, I'm pretty new to this forum so please bare with me if this is not the proper way to report this behaviour I have installed SH3D v7.2 OpenJDK v 11.1.18 - 64bit - 2GB Java3D v1.6.2a VideoRendering v2.4.1 Everything seems to work fine so far The only exception is the video rendering that only works the first time after loading the app Any further tentative to click on the "create" button in the "video rendering" window generates no results No crash, just no action I couldn't find anything similar in this forum or in the bugs repository Any idea what should I try? Thanks, Marco |
| Posted by hansmex at Mar 12, 2024, 2:33:33 AM |
Re: Video render works first time only Did you install the 64 bit or the 32 bit version of SH3D? H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by lubimaer at Mar 12, 2024, 6:04:14 AM |
Re: Video render works first time only Good question Downloading for windows automatically redirected me to an installer that I assumed it was 64bit But if I run SysInternal command from Microsoft it looks like the app is 32bit Here's SysInternal output C:\Program Files\Sweet Home 3D>\Users\cqvw46\Desktop\download2\sigcheck.exe SweetHome3D.exe Sigcheck v2.90 - File version and signature viewer Copyright (C) 2004-2022 Mark Russinovich Sysinternals - www.sysinternals.com C:\Program Files\Sweet Home 3D\SweetHome3D.exe: Verified: Signed Signing date: 5:35 AM 9/22/2023 Publisher: PUYBARET EMMANUEL Company: eTeks Description: Sweet Home 3D Product: Sweet Home 3D Prod version: 7.2 File version: 7.2 MachineType: 32-bit BUT Task Manager is telling me I'm running SH3D using: Zulu Platform x64 Architecture So the answer is: My machine is 64bit but I'm not sure what I'm running Marco |
| Posted by hansmex at Mar 12, 2024, 6:41:40 AM |
Re: Video render works first time only When installing, there's a screen that asks whether you want the 64 or 32 bit version. Please, reinstall and check... H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by lubimaer at Mar 12, 2024, 10:44:20 AM |
Re: Video render works first time only Hi Hans, Thanks for the feedback I have uninstalled SH3D and reinstalled selecting 64bit: Nothing changed. Is it possible to check logs for any error message? Thanks Marco |
| Posted by Puybaret at Mar 12, 2024, 11:01:18 AM |
Re: Video render works first time only How large is your SH3D file? Can you check in About dialog how much memory is used by the Sweet Home 3D before and after you render a video (the numbers cited after "64 bit")? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lubimaer at Mar 12, 2024, 6:36:25 PM |
Re: Video render works first time only Before = 0.1/2.8G After = 0.1/2.8G It happens with any file I've also created a very simple scene with just a chair Video works the first time but stops working after that Workaround is to close SH3D and restart Marco |
| Posted by Puybaret at Mar 12, 2024, 6:47:40 PM |
Re: Video render works first time only Thanks for the information. This doesn’t look like a memory shortage issue. Please run Sweet Home 3D from the command line with a command like: "C:\Program files\Sweet Home 3D\SweetHome3D.exe" 2>log.txt---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lubimaer at Mar 12, 2024, 8:04:30 PM |
Re: Video render works first time only Hi Emmanuel, Please find here the trace when starting the app WARNING: An illegal reflective access operation has occurred WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/C:/Program%20Files/Sweet%20Home%203D/lib/java3d-1.6/j3dcore.jar) to method sun.awt.AppContext.getAppContext() WARNING: Please consider reporting this to the maintainers of javax.media.j3d.JoglPipeline WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations WARNING: All illegal access operations will be denied in a future release Running a second time the video rendering adds the following Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: Comparison method violates its general contract! at java.base/java.util.ComparableTimSort.mergeHi(ComparableTimSort.java:870) at java.base/java.util.ComparableTimSort.mergeAt(ComparableTimSort.java:487) at java.base/java.util.ComparableTimSort.mergeCollapse(ComparableTimSort.java:413) at java.base/java.util.ComparableTimSort.sort(ComparableTimSort.java:213) at java.base/java.util.Arrays.sort(Arrays.java:1249) at java.desktop/sun.awt.shell.Win32ShellFolderManager2.get(Win32ShellFolderManager2.java:313) at java.desktop/sun.awt.shell.ShellFolder.get(ShellFolder.java:259) at java.desktop/com.sun.java.swing.plaf.windows.WindowsFileChooserUI$DirectoryComboBoxModel.addItem(WindowsFileChooserUI.java:1087) at java.desktop/com.sun.java.swing.plaf.windows.WindowsFileChooserUI.doDirectoryChanged(WindowsFileChooserUI.java:74 1) at java.desktop/com.sun.java.swing.plaf.windows.WindowsFileChooserUI$11.propertyChange(WindowsFileChooserUI.java:832) at java.desktop/java.beans.PropertyChangeSupport.fire(PropertyChangeSupport.java:341) at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:333) at java.desktop/java.beans.PropertyChangeSupport.firePropertyChange(PropertyChangeSupport.java:266) at java.desktop/java.awt.Component.firePropertyChange(Component.java:8731) at java.desktop/javax.swing.JFileChooser.setCurrentDirectory(JFileChooser.java:608) at java.desktop/javax.swing.JFileChooser.<init>(JFileChooser.java:362) at java.desktop/javax.swing.JFileChooser.<init>(JFileChooser.java:308) at com.eteks.sweethome3d.swing.FileContentManager$DirectoryChooser.<init>(Unknown Source) at com.eteks.sweethome3d.swing.FileContentManager.showFileChooser(Unknown Source) at com.eteks.sweethome3d.swing.FileContentManager.showSaveDialog(Unknown Source) at sh3dPlugin.AdvancedVideoPanel.startVideoCreation(AdvancedVideoPanel.java:1851) at sh3dPlugin.AdvancedVideoPanel.access$11(AdvancedVideoPanel.java:1844) at sh3dPlugin.AdvancedVideoPanel$10.actionPerformed(AdvancedVideoPanel.java:367) at java.desktop/javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1967) at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2308) at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:405) at java.desktop/javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:262) at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:279) at java.desktop/java.awt.Component.processMouseEvent(Component.java:6635) at java.desktop/javax.swing.JComponent.processMouseEvent(JComponent.java:3342) at java.desktop/java.awt.Component.processEvent(Component.java:6400) at java.desktop/java.awt.Container.processEvent(Container.java:2263) at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5011) at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321) at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843) at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4918) at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4547) at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4488) at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2307) at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2772) at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843) at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:772) at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721) at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95) at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745) at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:743) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85) at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742) at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203) at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124) at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113) at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109) at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90) |
| Posted by sjb007 at Mar 13, 2024, 2:05:16 AM |
Re: Video render works first time only Check the last couple of pages of the 7.2 release thread here in the forums. It looks like you have hit the same error as snmavronis. Perhaps Emmanuel could send you his 7.3 beta to test too. |
Current timezone is GMT Aug 26, 2026, 10:51:42 AM |
