Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Bottom view: 3D view |
| Print at Sep 26, 2026, 1:35:17 AM | |
| Posted by michellembrodeur at Jan 27, 2010, 9:19:29 PM |
Bottom view: 3D view I can rotate the virtual view, but how do I scroll it side to side and up and down. it is always dead centre from the size of your layout. thanks all |
| Posted by Puybaret at Jan 28, 2010, 4:16:17 PM |
Re: Bottom view: 3D view Please read Sweet Home 3D user's guide or the integrated help to discover what kind of moves you can do in the 3D view. Note that I added in version 2.3 a new indicator in the back of the virtual visitor shown in plan to let users easily change the elevation of his view point ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by michellembrodeur at Jan 29, 2010, 12:52:21 PM |
Re: Bottom view: 3D view So no way to scrolls side to side in the 3D view. |
| Posted by Puybaret at Jan 29, 2010, 2:48:41 PM |
Re: Bottom view: 3D view Hum... sorry I don't understand what you mean by "scrolling side to side". ![]() Please, try to describe what it is. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Jan 29, 2010, 5:11:59 PM |
Re: Bottom view: 3D view Emmanuel: I think the problem is that the 3D view always rotates around the center of the 3D image. Recently someone else also asked if it possible to change the center of rotation, so that you can zoom in on a part of the 3D view that lies at the edge of the model. Currently this isn't possible in SH3D. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Jan 29, 2010, 5:56:51 PM |
Re: Bottom view: 3D view The new indicator lets you easily change easily the elevation of the point of view. So I don't think I'll program in a close future the move of the center of rotation in Aerial view mode, because I want to keep this mode simple to be sure nobody looses himself in this mode and furthermore because there's nothing in the plan that indicates what you're seeing in the 3D view. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by magiccobra2000 at Mar 2, 2010, 10:09:49 PM |
Re: Bottom view: 3D view the answer is easy. if you select ´virtual visit´ in the menu ´3D view´, you will see a little icon appear in your plan. when you drag the mouse over this icon, you´ll see you can rotate the angle left to right, or up and down. when you double click on this icon, you can adjust the visitiors height. |
| Posted by michellembrodeur at Mar 3, 2010, 6:12:27 PM |
Re: Bottom view: 3D view Nope not what I was looking for. See when building the home I like the 3D view to help place walls specially the round one's. But since you cannot move the location of where the 3D view is from top down. Then i cannot see clearly where I cam placing walls and objects that are not in the center of the building. |
| Posted by magiccobra2000 at Mar 3, 2010, 7:53:13 PM |
Re: Bottom view: 3D view what if you set the visitors height on 2m? |
| Posted by michellembrodeur at Mar 3, 2010, 10:59:25 PM |
Re: Bottom view: 3D view it does not matter how tall the visitors icon is set too. i want a top down view of the walls for making the walls. seeing them from a front view walking does not help i need to see the whole layout and zoom in closer to put walls so they join up nicely. Try placing curves walls yourself and see the hassle it is and how easier it is when looking at them from a top down view. |
| Posted by tderida at May 22, 2010, 11:43:22 AM |
Re: Bottom view: 3D view I have the same issue; Actually the problem is fixed pivot point of the 3d view.That means, I can't pan the scene in X and Y axis 3d view. That feature will be good if the developer add it to this briliant software... |
| Posted by Puybaret at May 22, 2010, 12:23:40 PM |
Re: Bottom view: 3D view Sorry but the answer is still the same: use virtual visit mode, and elevate the visitor's point of view. If you need to see hidden parts, you can also change the walls transparency with 3D modification dialog. Aerial view mode is a simple view mode for beginners, and there won't be any option to make it more complicate to use in a close future. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by db4tech at May 23, 2010, 5:38:19 PM |
Re: Bottom view: 3D view it does not matter how tall the visitors icon is set too. i want a top down view of the walls for making the walls. seeing them from a front view walking does not help i need to see the whole layout and zoom in closer to put walls so they join up nicely. Try placing curves walls yourself and see the hassle it is and how easier it is when looking at them from a top down view. Hi michellembrodeur, What you are asking for is already available in the (top right display of the Sweet Home interface) Plan view, if it helps you can zoom right in to help with accurate object and wall placement, if using Sweet Home on a Windows computer press and hold the Ctrl key on your keyboard then rotate your mouse wheel back and forth to zoom in and out, releasing Ctrl and just rotating the mouse wheel causes the Plan view to scroll up and down . Hope this helps you build your model. db4tech |
| Posted by JimKnopf at Oct 19, 2017, 1:00:04 PM |
Re: Bottom view: 3D view Hi there, I have Sweet Home 3D Version 5.5.2 and basically I have the same issue as the original poster, however the virtual visit mode seems to be a good workarround for me. I even figured out that you can make a step to the left/right by pressing the <ALT> + <left/right arrow> and to speed up your steps you have to press <shift> simultaniously. e.g. <Shift><Alt><left/right arrow> I am starting to love Sweet Home 3D ... |
Current timezone is GMT Sep 26, 2026, 1:35:17 AM |
