Print at Sep 9, 2026, 11:11:23 PM View all posts in this thread on one page
Posted by ArtOfHome at Feb 15, 2024, 10:09:35 AM
MAgnetism and alignment side-by-side
When 2 objects are grouped together, magnetism doesn't work, is there a way?
Automatic side-by-side alignment doesn't work on all sides.
Posted by Puybaret at Feb 15, 2024, 10:22:44 AM
Re: MAgnetism and alignment side-by-side
Select them individually in the group by clicking a second time on one of the objects of the group then selecting the second one by clicking on it with shift key pressed. You may also select them in the furniture list.
Side by side alignment aligns the second and following objects of the selection on the back of the first selected object (opposite side of the thicker line of its selection rectangle), without rotating them. So pay attention to which object is first selected.
Posted by ArtOfHome at Feb 15, 2024, 12:08:05 PM
I know how to select multiple grouped objects.... The question was when I select one of the objects in the group, it doesn't magnetically snap to another object in the group. Do I have to separate them first...
Posted by Keet at Feb 15, 2024, 12:16:43 PM
Do the parts that need to be aligned with magnetism share the same elevation, or at least partial share in height? I found that objects on a different elevation don't align through magnetism.
Posted by Puybaret at Feb 15, 2024, 12:34:13 PM
Sorry, I didn't read you correctly. You're right, magentism doesn't work for objects within a group and you need to ungroup them first. Maybe I should improve this behavior...
Keet, your comment is right but magnetism doesn't work for two objects at different elevations only if the bottom of the higher object is higher than the top of the lower one. Logical, not?
Posted by Keet at Feb 15, 2024, 12:37:25 PM
Yep logical, I just though I would point it out since that might have been the cause of the failed magnetism snap. I totally missed the part that the two objects were in a group smile
It would be nice if magnetism would work inside a group, I often rearrange objects in a group.
Posted by ArtOfHome at Feb 15, 2024, 2:29:26 PM
Adding a "align top with bottom," for example, would suffice. Because in the case depicted in the image, if I use the "align side by side," they overlap. Yes, there's magnetism, but sometimes it's difficult. An "align top with bottom" or even "bottom with bottom" would be very useful.
example_image
