Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Eclipse/Ant Build "Failed Build" |
| Print at Sep 19, 2026, 11:02:48 PM | View all posts in this thread on one page |
| Posted by Ensoniq at Jan 15, 2010, 1:30:56 AM |
Eclipse/Ant Build "Failed Build" Hi. I'm pretty new to this but eager to learn, so I'm hoping this doesn't come of as a stupid Q. And hopefully someone on here has an answer. I've been trying to build Sweethome 3D using Eclipse and the Build.xml but have run into some minor issues. First I get this ----------------------------------------- ..\workspace\SweetHome3D\build.xml:40: Unable to find a javac compiler; com.sun.tools.javac.Main is not on the classpath. Perhaps JAVA_HOME does not point to the JDK. It is currently set to "C:\Program Files\Java\jre6" ------------------------------------------------------------- I added tools.jar from jdk 1.6.0_17 to the Ant runtime classpath and sure enough that worked.(probably the wrong way to go about it) Then this when building src\com\eteks\sweethome3d\applet\SweetHome3DApplet.java using Ant and the Build.xml --------------------------------------------------------------- :231: annotations are not supported in -source 1.3 [javac] (use -source 5 or higher to enable annotations) [javac] @SuppressWarnings("unchecked") [javac] ^ [javac] 1 error ---------------------------------------------------------------- If anyone can help I'ts greatly appreciated. Thanks. ![]() |
| Posted by Puybaret at Jan 15, 2010, 9:21:11 AM |
Re: Eclipse/Ant Build "Failed Build" Forget about JAVA_HOME. Here's my way to run Ant in Eclipse:
Note that in Targets tab there are many different Ant targets. Don't forget to create keys.keytool file first for javaWebStart, applet and viewer targets (see README.TXT file). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ensoniq at Jan 15, 2010, 9:42:27 PM |
Re: Eclipse/Ant Build "Failed Build" Hi and thanks for replying. I tried your suggestions but nothing seems to make any diffenrence \SweetHome3D\src\com\eteks\sweethome3d\applet\SweetHome3DApplet.java:231: annotations are not supported in -source 1.3 [javac] (use -source 5 or higher to enable annotations) [javac] @SuppressWarnings("unchecked") [javac] ^ [javac] 1 error Related to this line encoding="ISO-8859-1" target="1.1" source="1.2"/> in the Build.xml file and this line: @SuppressWarnings("unchecked") in SweetHome3DApplet.java Any other ideas? Regards |
| Posted by Puybaret at Jan 15, 2010, 11:37:26 PM |
Re: Eclipse/Ant Build "Failed Build" Don't be astonished if compilation fails: you must have added @SuppressWarnings("unchecked") annotation in SweetHome3DApplet.java and it's not supported in 1.2 source as reported in error message. Some times warnings are left on purpose... As written in SweetHome3DApplet javadoc: The bytecode of this class is Java 1.1 compatible to be able to notify users that it requires Java 5 when it's run under an old JVM. and again in build.xml: Compile Sweet Home 3D applets first with javac 1.1 to be able to detect current Java version during applet launch (otherwise Java 1.1 to 1.4 plug-ins refuse to load Applet class) ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ensoniq at Jan 16, 2010, 12:37:54 PM |
Re: Eclipse/Ant Build "Failed Build" Thanks. I honelstly have absolutely no idea how I did that but I guess thats the result of too much messing around with the settings when trying to build. Anyway, I reimported the source code and followed your instructions and... voila...build success. You have done an impressive job and Im going to enjoy learning this Thank you again. |
Current timezone is GMT Sep 19, 2026, 11:02:48 PM |
