Print at Sep 15, 2026, 5:56:47 AM
Posted by SHAGGYR at Jan 9, 2024, 2:39:00 AM
Join walls with different thickness
Hello, I have the following problem.
I create a project of my flat, and of course as any other flat i have inner walls which are thiner than the outher walls of the building.
And of course my inner walls inside the flat cross outer walls.
I don't get how can I make those walls merge, they simply lie on on top of another and collide.
This makes the project look bad and ruins all the dragging / resizing.
I looked in the docs and watched a couple of tutorials but I can't find an answer. Could some1 help?
I leave a link to pasteboard to share how my project looks like.
Posted by Puybaret at Jan 9, 2024, 12:05:54 PM
Re: Join walls with different thickness
Make the length of the thin walls smaller, or use the same pattern as the one you used for thicker walls.
Posted by SHAGGYR at Jan 9, 2024, 12:32:55 PM
Changing pattern to the same did the trick!
Thanks a lot.
