Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Join walls with different thickness |
| Print at Sep 15, 2026, 5:23:43 AM | View all posts in this thread on one page |
| Posted by SHAGGYR at Jan 9, 2024, 2:39:00 AM |
Join walls with different thickness Hello, I have the following problem. I create a project of my flat, and of course as any other flat i have inner walls which are thiner than the outher walls of the building. And of course my inner walls inside the flat cross outer walls. I don't get how can I make those walls merge, they simply lie on on top of another and collide. This makes the project look bad and ruins all the dragging / resizing. I looked in the docs and watched a couple of tutorials but I can't find an answer. Could some1 help? I leave a link to pasteboard to share how my project looks like. |
| Posted by Puybaret at Jan 9, 2024, 12:05:54 PM |
Re: Join walls with different thickness Make the length of the thin walls smaller, or use the same pattern as the one you used for thicker walls. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by SHAGGYR at Jan 9, 2024, 12:32:55 PM |
Re: Join walls with different thickness Changing pattern to the same did the trick! Thanks a lot. |
Current timezone is GMT Sep 15, 2026, 5:23:43 AM |
