Print at Oct 6, 2026, 2:32:59 AM
Posted by zuo at Dec 28, 2023, 9:33:36 AM
biggrin   Python Binding for Sweet Home 3D js
To get closer to recent improvement with python and AI I make a minimal Streamlit plugin for python. It with few line of code can draw programmatically the paramiters passed and it can also manually modified, that return the drawed configuration.
Codebase: https://gitlab.com/nicolalandro/streamlit-sweethome3d
Live preview: https://huggingface.co/spaces/z-uo/SweetHome3DPlanner
Any contribution and sharing is welcome.
Posted by Daniels118 at Dec 28, 2023, 11:14:59 AM
Re: Python Binding for Sweet Home 3D js
Sounds interesting. Do you count to make a chatbot to help users drawing their homes by giving build orders in natural language?
Posted by Puybaret at Dec 29, 2023, 10:31:06 AM
Interesting…
As it seems to be based on Sweet Home 3D JS, can you explain how it works? Are Python instructions interpreted in JavaScript?
By the way, don’t forget to set a license a on your GitHub projects, probably GNU GPL if it’s based on Sweet Home 3D or Sweet Home 3D JS.
Posted by zuo at Dec 29, 2023, 2:40:09 PM
I fix license by adding a GPLv3.
It is a component for Streamlit python lib. It create a web server with a frontend using python code that can interact with some callbacks with python. So I use vite to create the component that through streamlit callbacks get input and give output to python code.
Yes I want to made a chat for build things into SH3D but I need months for a working result.
