Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Help with rendering |
| Print at Sep 20, 2026, 6:23:29 PM | View all posts in this thread on one page |
| Posted by crackwood01 at Nov 21, 2023, 7:56:58 PM |
Help with rendering Hi, i'm getting rendering problems, is there something i can do the door looks gray and the quality looks blured config: AMD Ryzen 5 5600g windows 11 pro x64 32gb ram gpu g-force rtx 3060 12gb vram ![]() |
| Posted by DigitAle.Com at Nov 22, 2023, 3:42:59 AM |
Re: Help with rendering hello, since I often have the same problem, but I'm not an expert in SH3D, I'm using the workaround to waste some time to perform tests adding light sources, not visible but It resolves the problem of greysh stuff. I mean waste of time to find a good position and the right percentage of light setting... I don't think SH3D is using GPU acceleration, (not in my case) just be sure to use the 64 bit release (asked while installing the app. Then use a higher resolution while rendering, 1280 or 1600 x ... It takes time... I know. I use YafaRay rendering engine at 4th quality level, then go for a beer, a sandwich or a cigarette... SunFlow seems to be slower to me and creating unwanted white shiny bubbles... but agan, wait for expert users answers. Good Luck. Alessandro |
| Posted by hansmex at Nov 22, 2023, 7:23:32 AM |
Re: Help with rendering I can see two problems: 1 - the door - this seems to be a Sketchup model. When not all faces are textured, SH3D has problems similar to what we see. Make sure (using Sketchup) that your model has textures on all faces (inside and out) before exporting the model. 2 - black spots in ceiling lights - this is caused by light bulbs touching the ceiling. Lower the light bulbs and the black spots disappear. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by crackwood01 at Nov 22, 2023, 11:39:39 PM |
Re: Help with rendering Thanks for the reply, I will give it a try |
| Posted by Puybaret at Nov 23, 2023, 10:58:12 AM |
Re: Help with rendering About the door, you could also make invisible the materials of the inner faces of the furniture (must be the materials named "material"). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by crackwood01 at Nov 24, 2023, 2:14:13 AM |
Re: Help with rendering thank you all, worked perfectly ;) |
| Posted by crackwood01 at Nov 24, 2023, 2:46:00 AM |
Re: Help with rendering![]() |
| Posted by sjb007 at Nov 24, 2023, 3:20:02 AM |
Re: Help with rendering DAMN!!! That's a nice jump in quality. ![]() |
Current timezone is GMT Sep 20, 2026, 6:23:29 PM |
