Print at Sep 21, 2026, 12:17:49 PM
Posted by jllh76 at Nov 19, 2023, 7:39:09 PM
Export plan image
Hello,
There is a limitation of 10000 pixels to export the plan image.
Is it possible to remove this limitation to export images with more details?
Thanks in advance
Posted by Keet at Nov 19, 2023, 8:46:23 PM
Re: Export plan image
Did you use Plan>Export to SVG format? I haven't seen a limit there.
I just exported a huge plan to SVG. Result: a 74MB SVG file with 30591x30590 pixels. (The plan I used is about 306x306 meters.)
Inkscape had no problem opening it and that's where I got the pixel information from.
Which version of Sweet Home 3D did you use and on what system?
Posted by jllh76 at Nov 19, 2023, 10:16:20 PM
Hello Keet,
I'm using the latest version 7.2 and the goal is to have a png or jpeg file output.
My question was about Tool > Export plan image.
I just tried it with Plan > Export svg option, in fact the quality is perfect. With a converter behind, I was able to obtain a jpeg.
For a future version, it could be interesting to remove the limitation of Tool > Export plan image option to directly have a high resolution image file.
Thanks
Posted by Keet at Nov 19, 2023, 10:35:25 PM
Ah yes, that's a plugin I didn't install so I didn't think about it. But if the SVG option works for you then your problem is solved.
Posted by Daniels118 at Nov 20, 2023, 3:25:07 AM
I strongly recommend the installation of this plugin, which makes the exported svg smaller:
https://sourceforge.net/p/sweethome3d/plug-ins/43/
Posted by jllh76 at Nov 20, 2023, 2:24:25 PM
I installed your plugin Daniels118, thank you for your help
