Print at Sep 21, 2026, 3:19:20 PM
Posted by Thomas_H at Nov 1, 2023, 12:20:08 PM
applause   Synchronisation iCloud
Hello,
I recognized that there is now an app for the iPad.
Is there a synchronisation between the Mac desktop.app and the iPad.app?
Thanks in advance.
Posted by Puybaret at Nov 1, 2023, 8:21:36 PM
Re: Synchronisation iCloud
I've just checked but the current solution isn't perfect.
Files are compatible between apps, but under iOS, you can't save directly a file in iCloud drive. When you tap on Save button then Export button, the edited home is saved in SweetHome3D folder, and you'll have to copy it to iCloud drive afterwards with Files app. Opening a file found in iCloud drive is more simple: tap on Open button then Import button and select the file you want.
Posted by Thomas_H at Nov 2, 2023, 8:20:52 AM
Thanks for your reply, that sounds like a workable workaround.
In addition, it would be good if you could further expand the integration of iCloud.
Can you take this topic with you, or should I post it somewhere else still as a feature request?
