Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Recover corupt file |
| Print at Aug 21, 2026, 5:27:35 AM | View all posts in this thread on one page |
| Posted by seballa at Jan 8, 2010, 6:49:28 PM |
Recover corupt file Hi I toyed around with SH3D today. When I finished my room, I saved it and tried to unzip the file succefully. After that I reopened the file did some changes and saved again. Unfortunatly something got wrong and I cannot open the file anymore now. I tried to zip the files again and rename the file but sweethome3d can't open them. How do I repack an unziped sh3d file? Just ZIP and rename doesnt work |
| Posted by Puybaret at Jan 8, 2010, 9:32:32 PM |
Re: Recover corupt file It's not because a SH3D file is some kind of ZIP file that you should play with it in a zip program! The only tip I can give you is that Home entry must be the first entry in a SH3D file, if you want Sweet Home 3D be able to read it. Don't ask more if it still doesn't work after that... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by seballa at Jan 9, 2010, 1:49:23 PM |
Re: Recover corupt file Thanks a lot Puybaret! It actually did work. It was pure luck i played around with the file and unzipped it, because I did destroyed my file later. This is what I did to repack the unzipped files: I created a new ZIP only of the HOME file with winrar and used the compression setting: "save" I then drag and droped all other files into this archive one by one in numeric order, after that I did the same with the folder. I renamed the file from home.zip to myrecoveredfile.sh3d AND IT WORKED. THANKS Seballa |
| Posted by Puybaret at Jan 9, 2010, 2:01:00 PM |
Re: Recover corupt file I'm glad you succeeded! The next time you want to compress your SH3D file, use File > Save and compress menu item. It's much easier! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 21, 2026, 5:27:35 AM |
