Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Categories |
| Print at Aug 21, 2026, 9:54:00 PM |
| Posted by LaVache at Sep 8, 2023, 12:34:50 PM |
Re: Categories OK now it doesn't find Java from /SW3D/Java but I guess I could make a link to it instead to copy the folder ? I already successfully added a shortcut in my Menu but this run the script then nothing. Entry in the menu for Sweet Home 3D is : /usr/bin/flatpak run --branch=stable --arch=x86_64 --command=/app/bin/SweetHome3D --file-forwarding com.sweethome3d.Sweethome3d @@ %F @@![]() |
| Posted by dorin at Sep 8, 2023, 1:31:57 PM |
Re: Categories 1. When I've ask you "what you use" I mean the official linux installer version from here. I've verified again to be sure if I've miss something and I don't find any flatpack, appimage or whatever. 2. Like I've said already, until you don't use the official installer and installed as official instructions, I can't help you. 3. You are free to experiment with whatever you want but you will be mostly alone. Generally I don't get why some users prefer the hard way but this is not my job. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Keet at Sep 8, 2023, 2:03:04 PM |
Re: Categories What Linux distribution do you use? On my Debian/Mate system I have this: /your-directory-somewhere/SH3D/SweetHome3D-7.1 where the Sweet Home 3D 64 .tgz download is extracted. After extracting the .tgz in that directory there are subdirectories runtime/bin where the Java runtime resides. I use the Sweet Home 3D startup script SweetHome3D-Java3D-1_5_2 which looks like this: #!/bin/shThe default script SweetHome3D should work the same. For the Furniture Library Editor I have created this script in the same directory as the SweetHome3D-Java3D-1_5_2 script: #!/bin/shAs you can see I have created a directory 'tools' in the SH3D directory I use for the Sweet Home 3D installation. In that directory I have the various versions of the Furniture and Texture Library Editor .jar files. (You don't have to add the -Duser,name=?? to the script. I do that so it overrules the linux username that is otherwise used in .sh3d files. It's a security/privacy thing.) With this setup Sweet Home 3D and the Furniture Library Editor use the same Java runtime in the runtime/bin directory. Of course I did the same for the TextureLibraryEditor. You already know how to create the menu-items. I don't use these because I always work from the file manager. After a new install I right-click a .sh3d file and select the 'Open with other application' option. Then I browse to the SweetHome3D-Java3D-1_5_2 script and select that. On Debian/Mate I have the checkbox 'Remember ...' which makes the choice the default for .sh3d files. From now on I can just double-click on any .sh3d file and it will start Sweet Home 3D with that project. You can do the same for library files and of course for another version of Sweet Home 3D like the beta. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by LaVache at Sep 8, 2023, 2:04:18 PM |
Re: Categories Yes I understood but I forgot I also installed a Flatpack from my repository. I really thought I'm using the official Linux installer. I tested this official installation and it crashed too, even using its own Java version because it has its Runtime folder. I'll begin to remove the Flatpack installation. |
| Posted by LaVache at Sep 8, 2023, 2:11:50 PM |
Re: Categories Result is : ![]() |
| Posted by Keet at Sep 8, 2023, 2:19:00 PM |
Re: Categories If you are using the SweetHome3D script try using the SweetHome3D-Java3D-1_5_2 instead. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by LaVache at Sep 8, 2023, 2:24:39 PM |
Re: Categories Yep, that works. |
| Posted by LaVache at Sep 8, 2023, 3:40:35 PM |
Re: Categories I finally succeeded to launch Furniture Library Editor trough its script but it still crashes saying after relaunching .sh3f file is invalid. Texture Library Editor says same about .sh3t file without to have open a file. |
| Posted by Keet at Sep 8, 2023, 4:29:21 PM |
Re: Categories The script for the Furniture Library Editor I offered is meant to open a library using a double-click in the file manager. If you want to use the script to just start the editor remove the part -open "$1" from the last line. (If you use the script as is and run it directly it tries to open the library passed by the $1 command line parameter. Since there is no such parameter the 'file' is invalid.) ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by LaVache at Sep 8, 2023, 7:16:19 PM |
Re: Categories It looks like another Archive manager. And the Editor keeps crash when I try to edit something in my file. |
Current timezone is GMT Aug 21, 2026, 9:54:00 PM |
