Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Help version 6.6 to 7.1 update or installation |
| Print at Aug 20, 2026, 11:26:07 AM | |
| Posted by Abchillen at Jul 25, 2023, 11:05:59 AM |
Help version 6.6 to 7.1 update or installation Hello everyone :-) Please help, I have Linux Ubuntu 22 on my system. I currently have SweetHome3D version 6.6a installed, but I can neither update nor get the current version 7.1 (tgz) installed. Can I update? Or can someone help me how to install a tgz file with instructions? Thanks. |
| Posted by Keet at Jul 25, 2023, 12:14:24 PM |
Re: Help version 6.6 to 7.1 update or installation It might be helpful if you explained what you tried and/or why you can't get it installed. Have you tried the Linux installer? https://sourceforge.net/projects/sweethome3d/....1-linux-x64.tgz/download Otherwise here are step-by-step instructions for Ubuntu 22.04: https://tutorialforlinux.com/2023/02/18/sweet...nstallation-step-by-step/ ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by hansmex at Jul 25, 2023, 12:59:44 PM |
Re: Help version 6.6 to 7.1 update or installation It's a long time sine I last used Ubuntu. It used to be very easy to install SH3D (just unpack in a directory of your choice), but after a few updates it was almost impossible to update a program if it's not in the repository/appshop. Reason why I switched back to W10. You need to find the (hidden) directories where SH3D is installed. Search for the executable of SH3D and replace that with the new one. As far as I remember that should be enough. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Keet at Jul 25, 2023, 1:07:31 PM |
Re: Help version 6.6 to 7.1 update or installation I'm on Debian on which Ubuntu is based. I'm not sure if this means it's exactly the same on Ubuntu but I just extract the tgz in a directory I want and change the menu command to point to the new SweetHome3D-Java3D-1_5_2 script. Has worked for several new versions so far. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Jul 25, 2023, 1:52:36 PM |
Re: Help version 6.6 to 7.1 update or installation Maybe this subject indicated in download page will help. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 20, 2026, 11:26:07 AM |
