Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: complex wall shape |
| Print at Sep 20, 2026, 4:52:51 AM | View all posts in this thread on one page |
| Posted by codevark at Jul 12, 2023, 10:15:38 PM |
complex wall shape I'm imagining a roughly tetrahedronal structure. Each side is a right triangle with the lower corners cut off, leaning at a 45 degree angle to meet the edges of the other sides. Each side also has a roughly semicircular hole in it, which would line up with the second floor. Yes, I got this idea from looking at a plastic shipping brace that came in my air conditioner packaging. :) Is there a way to slope the bottom of a wall? If so, I can make a four-sectioned wall with slants, export as furniture, and rotate it appropriately. Otherwise, I have no idea how to do this. :P |
| Posted by Keet at Jul 12, 2023, 10:26:23 PM |
Re: complex wall shape Why would you want to slope the bottom of the wall if you are going to export for furniture anyway? Just slope the top, export, import, and turn it up-side-down! If you want a tetrahedron you could create that with the Generate 3D Shape tool (tools menu). And there is the geometric forms library from OK Hoff: https://sourceforge.net/p/sweethome3d/d-models/299/ Good luck! ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Keet at Jul 12, 2023, 10:33:28 PM |
Re: complex wall shape I forgot: there's a new relatively new function under the tools menu: Generate Basic Shape. Guess what? It also generates a tetrahedron! ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by codevark at Jul 12, 2023, 10:44:33 PM |
Re: complex wall shape nm, figured it out with an invisible triangle lol speaking of grids, a hexgrid would be nice for things like this. |
| Posted by codevark at Jul 12, 2023, 10:46:24 PM |
Re: complex wall shape the three triangles (missing the lower corners) will comprise the roof. can you generate a tetra and put windows in it? :) |
| Posted by codevark at Jul 12, 2023, 11:11:58 PM |
Re: complex wall shape I'll have to accurately measure my physical model and scale it. the angles are 45, but with the side lengths I'm using, the edges don't match up correctly. |
| Posted by Keet at Jul 12, 2023, 11:12:06 PM |
Re: complex wall shape Nope, you can only create holes in walls and floors. In walls you can use any object imported as "Door or window" and to create a hole in a floor you use a staircase. Export the wall or floor without selecting the object that creates the hole and the hole itself will be retained in the export. You can of course combine multiple geometric forms 'around' a hole and combine them for export. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 20, 2026, 4:52:51 AM |
