Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Debian: Crash SweetHome3D on startup |
| Print at Oct 5, 2026, 9:45:06 PM | |
| Posted by msize at Jan 2, 2010, 4:48:45 PM |
Debian: Crash SweetHome3D on startup Try startup SweetHome3D and have a problem: java: ../../src/xcb_io.c:461: _XRead: Assertion `dpy->xcb->reply_data != 0' failed. localhost:/opt/SweetHome3D-2.2 $ ./SweetHome3D What's the matter?java: ../../src/xcb_io.c:461: _XRead: Assertion `dpy->xcb->reply_data != 0' failed. localhost:/opt/SweetHome3D-2.2 $ ./jre1.6.0_17/bin/java -version java version "1.6.0_17" Java(TM) SE Runtime Environment (build 1.6.0_17-b04) Java HotSpot(TM) Client VM (build 14.3-b01, mixed mode) localhost:/opt/SweetHome3D-2.2 $ cat /etc/debian_version 5.0.3 localhost:/opt/SweetHome3D-2.2 $ uname -a Linux localhost 2.6.26-2-686 #1 SMP Wed Nov 4 20:45:37 UTC 2009 i686 GNU/Linux |
| Posted by hansmex at Jan 2, 2010, 5:42:38 PM |
Re: Debian: Crash SweetHome3D on startup In the FAQ there's a section on installation problems: have a look. Also, this question has been dealt with already many times before on this forum. Have a look at the messages. I had problems using Ubuntu 9.04, but since upgrading to Ubuntu 9.10 SH3D works like a charm, because the video drivers were updated. Good luck, Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Jan 2, 2010, 10:54:32 PM |
Re: Debian: Crash SweetHome3D on startup I don't know if this may help but looking for "java: ../../src/xcb_io.c:46...ta != 0' failed" may give you answers. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by msize at Jan 21, 2010, 5:55:04 AM |
Re: Debian: Crash SweetHome3D on startup Thank you for help. After updated graphics driver, it worked. |
Current timezone is GMT Oct 5, 2026, 9:45:06 PM |
