Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Textures attached to boxes sometimes stuck at 45 deg angle |
| Print at Aug 19, 2026, 2:31:30 AM | View all posts in this thread on one page |
| Posted by Remuddler at Jul 1, 2023, 7:43:17 PM |
Textures attached to boxes sometimes stuck at 45 deg angle I have built a box on FreeCAD and successfully imported it. It has 6 sides and when I select to add a texture it places the texture at a 45 deg angle rather than the selected angle of 0 deg. What am I doing wrong? |
| Posted by Keet at Jul 1, 2023, 8:21:50 PM |
Re: Textures attached to boxes sometimes stuck at 45 deg angle If you can assign a texture to each side individually you can select the 'wrong' side and rotate the texture to fit. If that doesn't work you will have to change your object in FreeCAD to make sure the texture is aligned correctly, which is probably the reason for the problem. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by hansmex at Jul 2, 2023, 9:33:07 AM |
Re: Textures attached to boxes sometimes stuck at 45 deg angle Or you could use the standard box in SH3D which has its textures oriented correctly... H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Aug 19, 2026, 2:31:30 AM |
