Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Help with external dimensions |
| Print at Sep 6, 2026, 8:27:39 AM | |
| Posted by kodb at Jan 2, 2010, 4:04:48 PM |
Help with external dimensions Happy New Year to all! I just found and installed this program; it is great and running under Ubuntu 9.1 64bit flawlessly. My question is: is there a way to change the default external dimensions? My home with garage attached is a long structure and we are adding a shop addition on the end of this which will make it REAL long (`130ft all told). Is there a way to stretch the default pane to accomodate this sizing? My total dimensions when done with current construction will be about 50 x 126 feet amd I would love to use this program to layout the new shopspace and quest quarters. Thanks, Bob |
| Posted by hansmex at Jan 2, 2010, 4:31:11 PM |
Re: Help with external dimensions Bob, I'm not sure I fully understand the question. The grid in SH3D is self-stretching, so if you start at coordinate 0,0 and want to add something at -200,-200 than that is no problem at all. Just drag it there, and you'll see that the grid expands. If this doesn't clarify your question, please explain again. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by kodb at Jan 2, 2010, 11:55:04 PM |
Re: Help with external dimensions Thanks Hans! I didn't appreciate the expanding properties of the grid as it did not do so at first. I found I had to run the cursor beyond the edges and then go back and forth as it would not pull/stretch just by moving the cursor beyond the edges of the window. I'm using the 64bit version on Ubuntu 9.1 with all updates and java updates. Once I did that it worked like a charm and I've spent the last 4 hours successfully getting the floorplans ginned up. Thanks guys this is a great program and I'm going to recommend it highly. Bob |
| Posted by drgnlvr86 at Jan 18, 2015, 9:00:49 PM |
Re: Help with external dimensionsQuestion similarly related. I accidentally self stretched to -80 feet, it froze for a second and then my wall was super long. Is there a way to get the grid back to -10' like I had it before? |
| Posted by Puybaret at Jan 19, 2015, 3:59:44 PM |
Re: Help with external dimensions Just close and reopen your file ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 8:27:39 AM |
