Print at Sep 6, 2026, 8:18:12 AM View all posts in this thread on one page
Posted by kodb at Jan 2, 2010, 4:04:48 PM
Help with external dimensions
Happy New Year to all!
I just found and installed this program; it is great and running under Ubuntu 9.1 64bit flawlessly.
My question is: is there a way to change the default external dimensions? My home with garage attached is a long structure and we are adding a shop addition on the end of this which will make it REAL long (`130ft all told). Is there a way to stretch the default pane to accomodate this sizing? My total dimensions when done with current construction will be about 50 x 126 feet amd I would love to use this program to layout the new shopspace and quest quarters.
Thanks,
Bob
Posted by hansmex at Jan 2, 2010, 4:31:11 PM
Re: Help with external dimensions
Bob,
I'm not sure I fully understand the question. The grid in SH3D is self-stretching, so if you start at coordinate 0,0 and want to add something at -200,-200 than that is no problem at all. Just drag it there, and you'll see that the grid expands.
If this doesn't clarify your question, please explain again.
Posted by kodb at Jan 2, 2010, 11:55:04 PM
Thanks Hans! I didn't appreciate the expanding properties of the grid as it did not do so at first. I found I had to run the cursor beyond the edges and then go back and forth as it would not pull/stretch just by moving the cursor beyond the edges of the window. I'm using the 64bit version on Ubuntu 9.1 with all updates and java updates.
Once I did that it worked like a charm and I've spent the last 4 hours successfully getting the floorplans ginned up.
Thanks guys this is a great program and I'm going to recommend it highly.
Bob
Posted by drgnlvr86 at Jan 18, 2015, 9:00:49 PM
confused   Re: Help with external dimensions
Question similarly related. I accidentally self stretched to -80 feet, it froze for a second and then my wall was super long. Is there a way to get the grid back to -10' like I had it before?
Posted by Puybaret at Jan 19, 2015, 3:59:44 PM
Just close and reopen your file
