Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: running source code in eclipse |
| Print at Aug 25, 2026, 11:49:16 AM | View all posts in this thread on one page |
| Posted by buzzz at Jun 19, 2023, 10:55:13 AM |
running source code in eclipse Hi all I try to run SW Java source code in Eclipse. I use Java 15 and eclipse 2021. I select as main class : com.eteks.sweethome3d.SweetHome3DBootstrap I have strange errors : WARNING: An illegal reflective access operation has occurred WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline Can't load library: C:\Users\toto\Desktop\SweetHome3D-7.1-src\natives\windows-amd64\gluegen_rt.dll Strangely, building the jar with ant works well and jar run fine |
| Posted by Puybaret at Jun 19, 2023, 11:35:13 AM |
Re: running source code in eclipse Did you follow the instructions in the README.TXT file of SweetHome3D project? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by buzzz at Jun 19, 2023, 4:44:11 PM |
Re: running source code in eclipse Oups... yes, I forget to add the VM arguments, it now works. I still have an error with the substring call here : with : jarfile = C:/Users/toto/Desktop/SweetHome3D-7.1-src/classes/com/eteks/sweethome3d/SweetHome3DBootstrap.class |
| Posted by Puybaret at Jun 20, 2023, 12:13:32 AM |
Re: running source code in eclipse Select com.eteks.sweethome3d.SweetHome3D as main class. com.eteks.sweethome3d.SweetHome3DBootstrap is made to be run from a JAR executable or Applet / Java Web Start environment. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by buzzz at Jun 20, 2023, 12:25:57 AM |
Re: running source code in eclipse thank you very much |
| Posted by buzzz at Jun 20, 2023, 4:24:20 PM |
Re: running source code in eclipse Hi I have some problems with openJDK15, GUI is not refreshing correctly, some buttons are placed incorrectly, windows screen update is done partially. So I suppose, I will install the last version of the JDK to run the app. Nevertheless, I need to compile with an older version. Which jre version do you recommend to run SW 7.1 in eclipse ? |
| Posted by Puybaret at Jun 21, 2023, 3:00:09 AM |
Re: running source code in eclipse I mainly use Eclipse under macOS so I'm not sure my advice will interest you. Anyway the best advice is to follow Eclipse recommandations. It's also possible to install more than a JDK in your system and use them in Eclipse. At this moment, I have 5 different JDKs/JREs configured in my Eclipse installation. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by buzzz at Jun 21, 2023, 4:31:34 AM |
Re: running source code in eclipse Thks I notice that I have no problem when running the jar with openjdk15 So I install Eclipse last version and everything works fine. |
| Posted by AvinashC at Apr 3, 2024, 11:58:18 AM |
Re: running source code in eclipse Hi all, I am trying to run the code from the git repo: https://github.com/SweetHome3D/SweetHome3D I am currently using the latest version Eclipse and jdk i am running the code with com.eteks.sweethome3d.SweetHome3DBootstrap as the main class with the arguments -classpath lib/java3d-1.6:<other_directories_or_jars> -Djava.library.path=lib/java3d-1.6/macosx -Djogamp.gluegen.UseTempJarCache=false as i am using mac i am getting the following errors 2024-04-03 14:26:14.327 java[1597:45750] WARNING: Secure coding is automatically enabled for restorable state! However, not on all supported macOS versions of this application. Opt-in to secure coding explicitly by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState:. Exception in thread "main" java.lang.NoClassDefFoundError: javax/media/opengl/GLCapabilitiesChooser at java.base/java.lang.Class.forName0(Native Method) at java.base/java.lang.Class.forName(Class.java:375) at javax.media.j3d.Pipeline$1.run(Pipeline.java:162) at java.base/java.security.AccessController.doPrivileged(AccessController.java:318) at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:157) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:965) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299) at javax.media.j3d.GraphicsConfigTemplate3D.isGraphicsConfigSupported(GraphicsConfigTemplate3D.java:351 ) at com.eteks.sweethome3d.j3d.Component3DManager.createGraphicsConfigurationTemplate3D(Component3DManage r.java:112) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:83) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:160) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:642) at com.eteks.sweethome3d.SweetHome3D.init(SweetHome3D.java:467) at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:370) Caused by: java.lang.ClassNotFoundException: javax.media.opengl.GLCapabilitiesChooser at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:641) at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:188) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525) ... 14 more Could you please help with this |
| Posted by Puybaret at Apr 3, 2024, 5:35:12 PM |
Re: running source code in eclipse This repository is not official and apparently not maintained. Use the repository at SourceForge.net or a source code archive, and be sure to read the README.TXT included file. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 25, 2026, 11:49:16 AM |
