Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Errors creating plugin class |
| Print at Sep 20, 2026, 11:29:02 PM | |
| Posted by daytooner at Apr 14, 2023, 3:32:59 AM |
Errors creating plugin class I have followed the instructions here: https://www.sweethome3d.com/pluginDeveloperGuide.jsp to generate a basic plugin. But when I generate the VolumePlugin class, I get the error: "The type com.eteks.sweethome3d.plugin.Plugin is not accessible" Here is the code that was generated: package com.eteks.test;Did I miss something? TIA ken |
| Posted by Puybaret at Apr 14, 2023, 4:03:46 PM |
Re: Errors creating plugin class You probably use a compiler compliance level ≥ 9. Change compiler compliance level to 1.8 in project properties or maybe accept Eclipse's quick fix Add 'requires SweetHome3D' to module-info.java ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 11:29:02 PM |
