Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Furniture .obj import crash and workaround (SH3D 7.1) |
| Print at Sep 29, 2026, 7:56:38 AM | View all posts in this thread on one page |
| Posted by Belvedere2022 at Apr 7, 2023, 2:21:17 PM |
Furniture .obj import crash and workaround (SH3D 7.1) I ran into the known bug that crashes SH3D on some systems while trying to import a furniture .obj Trying the workaround of manually running the SH3D .jar - either via the GUI or from the console did not work for me. I tried this on both java versions that are installed on my system. Console output below: administrator@kallisti:/usr/local/src/SweetHome3D-7.1/lib$ /usr/lib/jvm/java-8-oracle/bin/java -version java version "1.8.0_144" Java(TM) SE Runtime Environment (build 1.8.0_144-b01) Java HotSpot(TM) 64-Bit Server VM (build 25.144-b01, mixed mode) administrator@kallisti:/usr/local/src/SweetHome3D-7.1/lib$ /usr/lib/jvm/java-8-oracle/bin/java -jar SweetHome3D.jar Error: Invalid or corrupt jarfile SweetHome3D.jar administrator@kallisti:/usr/local/src/SweetHome3D-7.1/lib$ /usr/lib/jvm/java-11-openjdk-amd64/bin/java -version openjdk version "11.0.18" 2023-01-17 OpenJDK Runtime Environment (build 11.0.18+10-post-Ubuntu-0ubuntu120.04.1) OpenJDK 64-Bit Server VM (build 11.0.18+10-post-Ubuntu-0ubuntu120.04.1, mixed mode, sharing) administrator@kallisti:/usr/local/src/SweetHome3D-7.1/lib$ /usr/lib/jvm/java-11-openjdk-amd64/bin/java -jar SweetHome3D.jar Error: Invalid or corrupt jarfile SweetHome3D.jar However, with the java-11-openjdk-amd64 version, I was able to run the furniture library editor from the console, successfully import the .obj and save it as a new library. I can now import the library in the main program. Note that this does NOT work when using the GUI. administrator@kallisti:/usr/local/src/SweetHome3D-7.1/lib$ /usr/lib/jvm/java-11-openjdk-amd64/bin/java -jar FurnitureLibraryEditor-1.31.jar Using java-8-oracle gives me a segfault: administrator@kallisti:/usr/local/src/SweetHome3D-7.1/lib$ /usr/lib/jvm/java-8-oracle/bin/java -jar FurnitureLibraryEditor-1.31.jar # # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x00007f71752fc028, pid=373764, tid=0x00007f7137a65700 # # JRE version: Java(TM) SE Runtime Environment (8.0_144-b01) (build 1.8.0_144-b01) # Java VM: Java HotSpot(TM) 64-Bit Server VM (25.144-b01 mixed mode linux-amd64 compressed oops) # Problematic frame: # C [libawt_xawt.so+0x42028] ReadRegionsInList+0x3b8 # # Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again # # An error report file with more information is saved as: # /usr/local/src/SweetHome3D-7.1/lib/hs_err_pid373764.log # # If you would like to submit a bug report, please visit: # http://bugreport.java.com/bugreport/crash.jsp # The crash happened outside the Java Virtual Machine in native code. # See problematic frame for where to report the bug. # Aborted (core dumped) I can provide the logfile in a DM if needed. |
| Posted by Belvedere2022 at Apr 7, 2023, 2:41:54 PM |
Re: Furniture .obj import crash and workaround (SH3D 7.1) Using this desktop entry (replace with your java and .jar locations) also worked for me: [Desktop Entry] X-AppInstall-Package=sweethome3d-furniture-editor X-AppInstall-Popcon=13 X-AppInstall-Section=universe Version=1.0 Name=Sweet Home 3D Furniture Library Editor GenericName=Sweet Home 3D Furniture Library Editor Comment=Create your own SweetHome3D furniture libraries Exec=/usr/lib/jvm/java-11-openjdk-amd64/bin/java -jar /usr/local/src/SweetHome3D-7.1/lib/FurnitureLibraryEditor-1.31.jar Icon=/usr/local/src/SweetHome3D-7.1/SweetHome3DIcon.png StartupNotify=true StartupWMClass=com-eteks-furniturelibraryeditor-FurnitureLibraryEditorBootstrap Terminal=false Type=Application Categories=Graphics;2DGraphics;3DGraphics; Keywords=interior;design;2D;3D;home;house;furniture;java;editor; X-Ubuntu-Gettext-Domain=app-install-data |
Current timezone is GMT Sep 29, 2026, 7:56:38 AM |
