Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Dual Monitor - 3d in separate window, back to main window makes sh3d unresponsive |
| Print at Sep 29, 2026, 8:50:02 AM | |
| Posted by Belvedere2022 at Apr 3, 2023, 12:06:43 AM |
Dual Monitor - 3d in separate window, back to main window makes sh3d unresponsive Hello, This happens with SH3D 7.0.2 and 7.1 on Ubuntu 20.04 LTS with Mesa IntelĀ® HD Graphics 5500 (BDW GT2) on Wayland. When working with two monitors: opening SH3D on the main monitor and dragging it to the secondary (located on the right) makes the program unresponsive when using CTRL-ALT-Y to move the 3d view to a separate window, and then CTRL-ALT-Y to move it back into the main program window. The 3d window disappears, in the main window the only possible action is to minimize/maximize. Looks like a focus issue, the only way to close the program is to issue a kill command. After a bit of testing, it seems that the CTRL-ALT-Y interaction breaks when the program is not on the leftmost window. All is good as long as the program window is located on the leftmost screen. e.g. no problems if the secondary screen is positioned on the left of the primary monitor. FWIW my ps output: administrator@kallisti:~$ ps -auxww | grep swe adminis+ 101040 15.3 1.9 5942712 312816 ? Sl 22:24 0:16 /usr/local/src/SweetHome3D-7.1/runtime/bin/java -Xmx2g -classpath /usr/local/src/SweetHome3D-7.1/lib/SweetHome3D.jar:/usr/local/src/SweetHome3D-7.1/lib/Furniture.jar:/usr/local/src/SweetHome3D-7.1/lib/Textures.jar:/usr/local/src/SweetHome3D-7.1/lib/Examples.jar:/usr/local/src/SweetHome3D-7.1/lib/Help.jar:/usr/local/src/SweetHome3D-7.1/lib/batik-svgpathparser-1.7.jar:/usr/local/src/SweetHome3D-7.1/lib/jeksparser-calculator.jar:/usr/local/src/SweetHome3D-7.1/lib/iText-2.1.7.jar:/usr/local/src/SweetHome3D-7.1/lib/freehep-vectorgraphics-svg-2.1.1c.jar:/usr/local/src/SweetHome3D-7.1/lib/sunflow-0.07.3i.jar:/usr/local/src/SweetHome3D-7.1/lib/jmf.jar:/usr/local/src/SweetHome3D-7.1/lib/java3d-1.6/j3dcore.jar:/usr/local/src/SweetHome3D-7.1/lib/java3d-1.6/j3dutils.jar:/usr/local/src/SweetHome3D-7.1/lib/java3d-1.6/vecmath.jar:/usr/local/src/SweetHome3D-7.1/lib/java3d-1.6/gluegen-rt.jar:/usr/local/src/SweetHome3D-7.1/lib/java3d-1.6/jogl-java3d.jar:/usr/local/src/SweetHome3D-7.1/lib/jnlp.jar -Djava.library.path=/usr/local/src/SweetHome3D-7.1/lib/java3d-1.6:/usr/local/src/SweetHome3D-7.1/lib/yafaray -Djogamp.gluegen.UseTempJarCache=false -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer com.eteks.sweethome3d.SweetHome3D -open adminis+ 101178 0.0 0.0 9412 656 pts/1 S+ 22:26 0:00 grep --color=auto swe administrator@kallisti:~$ kill 101040 |
| Posted by Belvedere2022 at Apr 7, 2023, 11:41:55 AM |
Re: Dual Monitor - 3d in separate window, back to main window makes sh3d unresponsive Looks like I described the same issue as here: https://sourceforge.net/p/sweethome3d/bugs/1167/ and possibly related: https://sourceforge.net/p/sweethome3d/bugs/1127/ |
Current timezone is GMT Sep 29, 2026, 8:50:02 AM |
