Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Retaining walls and elevated lawns |
| Print at Aug 15, 2026, 6:44:08 AM | |
| Posted by jamesnz at Mar 31, 2023, 6:48:26 AM |
Retaining walls and elevated lawns Hi, Thanks for the fantastic software, brilliant. I have a question about the ground outside the house, we have a 2m elevation supported by a retaining wall. I want to emulate the grass and cobblestones on that raised level but how to achieve ? Should I be making it a room and colouring /texturing the top to emulate or is there another way.any help appreciated. |
| Posted by Puybaret at Mar 31, 2023, 11:24:42 AM |
Re: Retaining walls and elevated lawns Adding a textured room in a new level at 2m elevation is a good solution. See this video at 0:58, if you want to learn how to draw one room around your home without covering it. If the ground isn't level, you can also try the Terrain generator plug-in ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jamesnz at Mar 31, 2023, 11:45:18 AM |
Re: Retaining walls and elevated lawns Brilliant, thankyou ! |
Current timezone is GMT Aug 15, 2026, 6:44:08 AM |
