Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: install sweethome 3D 7.1 on Linux Elementary OS |
| Print at Sep 29, 2026, 11:31:43 AM |
| Posted by Wololo at Mar 21, 2023, 3:45:33 PM |
install sweethome 3D 7.1 on Linux Elementary OS Hello, i have just instaled sweethome 3D 7.1 on my computer. I have exactly followed the instruction of this link which is linked on the official download page. I have currently these 2 issues:
Many thanks in advance for your help, OS: Linux Elementary OS 6.1 (fork of Linux Ubuntu) |
| Posted by Wololo at Mar 23, 2023, 10:57:47 AM |
Re: install sweethome 3D 7.1 on Linux Elementary OSi have tried today installing versions 7.0.1 back, then version 6.5 as well. The software interface menus texts are still very big, there is no change compared to my screenshot of the previous message. My .desktop file is like this: [Desktop Entry]has someone an idea how i can make the menu texts size smaller? |
| Posted by Puybaret at Mar 23, 2023, 11:26:05 AM |
Re: install sweethome 3D 7.1 on Linux Elementary OS Try to set the properties listed in the FAQ Texts in the furniture catalog are not displayed correctly or icons in the toolbar appear very small on my computer. How can I fix that? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Wololo at Mar 23, 2023, 1:51:39 PM |
Re: install sweethome 3D 7.1 on Linux Elementary OS Try to set the properties listed in the FAQ Texts in the furniture catalog are not displayed correctly or icons in the toolbar appear very small on my computer. How can I fix that? Many thanks. The FAQ says Under Linux, edit SweetHome3D script and add the previous options before -classpath Java option without line returns. under Linux, the SweetHome3D script has 11 rows. The row 11 is: exec "$PROGRAM_DIR"/runtime/bin/java -Xmx2g -classpath "$PROGRAM_DIR"/lib/SweetHome3D.jar:"$PROGRAM_DIR"/lib/Furniture.jar:"$PROGRAM_DIR"/lib/Textures.jar:"$PROGRAM_DIR"/lib/Examples.jar:"$PROGRAM_DIR"/lib/Help.jar:"$PROGRAM_DIR"/lib/batik-svgpathparser-1.7.jar:"$PROGRAM_DIR"/lib/jeksparser-calculator.jar:"$PROGRAM_DIR"/lib/iText-2.1.7.jar:"$PROGRAM_DIR"/lib/freehep-vectorgraphics-svg-2.1.1c.jar:"$PROGRAM_DIR"/lib/sunflow-0.07.3i.jar:"$PROGRAM_DIR"/lib/jmf.jar:"$PROGRAM_DIR"/lib/java3d-1.6/j3dcore.jar:"$PROGRAM_DIR"/lib/java3d-1.6/j3dutils.jar:"$PROGRAM_DIR"/lib/java3d-1.6/vecmath.jar:"$PROGRAM_DIR"/lib/java3d-1.6/gluegen-rt.jar:"$PROGRAM_DIR"/lib/java3d-1.6/jogl-java3d.jar:"$PROGRAM_DIR"/lib/jnlp.jar -Djava.library.path="$PROGRAM_DIR"/lib/java3d-1.6:"$PROGRAM_DIR"/lib/yafaray -Djogamp.gluegen.UseTempJarCache=false -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer com.eteks.sweethome3d.SweetHome3D -open "$1"Should i edit the script for the row 11 like this? exec "$PROGRAM_DIR"/runtime/bin/java -Xmx2g -Dcom.eteks.sweethome3d.resolutionScale=2.5 -Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel -Dswing.plaf.metal.controlFont=Dialog-11 -Dswing.plaf.metal.userFont=SansSerif-11 -Dswing.plaf.metal.systemFont=SansSerif-11 -classpath "$PROGRAM_DIR"/lib/SweetHome3D.jar:"$PROGRAM_DIR"/lib/Furniture.jar:"$PROGRAM_DIR"/lib/Textures.jar:"$PROGRAM_DIR"/lib/Examples.jar:"$PROGRAM_DIR"/lib/Help.jar:"$PROGRAM_DIR"/lib/batik-svgpathparser-1.7.jar:"$PROGRAM_DIR"/lib/jeksparser-calculator.jar:"$PROGRAM_DIR"/lib/iText-2.1.7.jar:"$PROGRAM_DIR"/lib/freehep-vectorgraphics-svg-2.1.1c.jar:"$PROGRAM_DIR"/lib/sunflow-0.07.3i.jar:"$PROGRAM_DIR"/lib/jmf.jar:"$PROGRAM_DIR"/lib/java3d-1.6/j3dcore.jar:"$PROGRAM_DIR"/lib/java3d-1.6/j3dutils.jar:"$PROGRAM_DIR"/lib/java3d-1.6/vecmath.jar:"$PROGRAM_DIR"/lib/java3d-1.6/gluegen-rt.jar:"$PROGRAM_DIR"/lib/java3d-1.6/jogl-java3d.jar:"$PROGRAM_DIR"/lib/jnlp.jar -Djava.library.path="$PROGRAM_DIR"/lib/java3d-1.6:"$PROGRAM_DIR"/lib/yafaray -Djogamp.gluegen.UseTempJarCache=false -Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer com.eteks.sweethome3d.SweetHome3D -open "$1" |
| Posted by Puybaret at Mar 23, 2023, 3:28:47 PM |
Re: install sweethome 3D 7.1 on Linux Elementary OS Yes. Hope it will work better. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Wololo at Mar 23, 2023, 4:22:28 PM |
Re: install sweethome 3D 7.1 on Linux Elementary OS unfortunately it has not brough the expected result. Now, all the interface is written in a huge size. You can see what a "normal size" would be if you compare the window's header (where the file name "sans titre" appears: ![]() How can i reduce de size of the menu texts? |
| Posted by Puybaret at Mar 23, 2023, 6:08:09 PM |
Re: install sweethome 3D 7.1 on Linux Elementary OS Change the values you set! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Wololo at Mar 24, 2023, 10:05:18 AM |
Re: install sweethome 3D 7.1 on Linux Elementary OSChange the values you set! problème résolu ! many thanks for the simple suggestion, at the end the proper factor was 1.0 :) in resolutionScale=1.0i have tried with resolution = 2.5 as said in the FAQ, then with resolution = 0.5, =0.75 and finally = 1.0 i haven't thought to set 1.0 because i was supposing that this is the standard value which doesn't need an extra specification of it.... here the rows 10 and the beginning of row 11: # Run Sweet Home 3D |
| Posted by Wololo at Mar 28, 2023, 6:16:18 PM |
Re: install sweethome 3D 7.1 on Linux Elementary OS Actually my initial point 2 has been "forgotten" while point 1 has been resolved
Many thanks in advance for your help, OS: Linux Elementary OS 6.1 (fork of Linux Ubuntu) does someone have an idea on this issue? |
| Posted by Keet at Mar 28, 2023, 8:56:00 PM |
Re: install sweethome 3D 7.1 on Linux Elementary OS Note the location of the SweetHome3D start script. This is the script you edited before. Right click on a .sh3d file Click "Open With Other Application" Navigate to the SweetHome3D script and select to open with that script. Don't forget to mark "Remember this applicatpon for sh3d documents". From now on double clicking on a sh3d file should start SweetHome3D with the clicked file. (This is on Debian but it's probably the same on Elementary.) ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 29, 2026, 11:31:43 AM |
