Print at Oct 5, 2026, 9:09:19 PM
Posted by DawnC86548 at Mar 17, 2023, 4:21:43 AM
Own picture into picture frame
HI,
I am using one of the picture frames in a room. Is there a way to switch the picture used in the frame for one of my own personal picture?
Thanks
Posted by Puybaret at Mar 17, 2023, 7:07:06 AM
Re: Own picture into picture frame
This video should help you.
Posted by DawnC86548 at Mar 17, 2023, 5:50:51 PM
thank you!!
Posted by Nayborex at Jan 31, 2025, 6:26:56 AM
If it’s a standard picture frame, you should be able to just pop the back open and swap out the image for your own.
Posted by Keet at Feb 11, 2025, 12:15:56 PM
@Nayborex
You are responding to a very old post. The question was not about a real picture frame but a 3D model as used in Sweet Home 3D.
In most cases changing the picture is simply replacing the texture for the picture with you own jpg/png image. Just make sure that the scale is the same as the original picture.
