Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Own picture into picture frame |
| Print at Oct 5, 2026, 8:51:21 PM | View all posts in this thread on one page |
| Posted by DawnC86548 at Mar 17, 2023, 4:21:43 AM |
Own picture into picture frame HI, I am using one of the picture frames in a room. Is there a way to switch the picture used in the frame for one of my own personal picture? Thanks |
| Posted by Puybaret at Mar 17, 2023, 7:07:06 AM |
Re: Own picture into picture frame This video should help you. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by DawnC86548 at Mar 17, 2023, 5:50:51 PM |
Re: Own picture into picture frame thank you!! |
| Posted by Nayborex at Jan 31, 2025, 6:26:56 AM |
Re: Own picture into picture frame If it’s a standard picture frame, you should be able to just pop the back open and swap out the image for your own. |
| Posted by Keet at Feb 11, 2025, 12:15:56 PM |
Re: Own picture into picture frame @Nayborex You are responding to a very old post. The question was not about a real picture frame but a 3D model as used in Sweet Home 3D. In most cases changing the picture is simply replacing the texture for the picture with you own jpg/png image. Just make sure that the scale is the same as the original picture. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 8:51:21 PM |
