Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Process for orthographic, outlined, sectioned, images. |
| Print at Sep 20, 2026, 5:01:29 PM |
| Posted by Puybaret at Dec 11, 2023, 5:10:35 PM |
Re: Process for orthographic, outlined, sectioned, images. I just tried under Windows 10 and it worked, but apparently, you have to select both in the outline setting of Pan 3D view plug-in. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by NIMAN at Dec 11, 2023, 8:12:54 PM |
Re: Process for orthographic, outlined, sectioned, images. I just tried under Windows 10 and it worked, but apparently, you have to select both in the outline setting of Pan 3D view plug-in. I had already tried (restarting SH3D after making the setting change) - unfortunately with no success: https://postimg.cc/ZBtXTKSK Anyway, appreciate you having had a look. |
| Posted by Puybaret at Dec 11, 2023, 8:33:43 PM |
Re: Process for orthographic, outlined, sectioned, images. Do you use the last version of Side view plug-in? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by NIMAN at Dec 11, 2023, 8:45:06 PM |
Re: Process for orthographic, outlined, sectioned, images. 1.0 at the minute. I had tried to update yesterday to 1.1 Beta 5 using Daniele's plugin manager but after the message box "Are you sure you want to install it" followed by YES click it had (and still does) reports an Error to the 1.1.Beta5.sh3p url |
| Posted by NIMAN at Dec 11, 2023, 8:49:25 PM |
Re: Process for orthographic, outlined, sectioned, images. Apologies Emmanuel, I just installed 1.1 from the plugins section at your homepage - the outline is now there in Win 10. |
| Posted by Daniels118 at Dec 13, 2023, 3:29:16 PM |
Re: Process for orthographic, outlined, sectioned, images. The problem with the Plugin Manager was that the beta version of Side view plugin is no longer available for download at that url. I have updated the plugins list with the final release of the Side view plugin (1.1) which can now be installed without any issue. |
| Posted by Puybaret at Dec 13, 2023, 3:34:01 PM |
Re: Process for orthographic, outlined, sectioned, images. Sorry for removing the Beta version of the plug-in, but I tend to do some clean up when final releases are out. Great it works now for you Niman ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by NIMAN at Dec 14, 2023, 2:01:18 PM |
Re: Process for orthographic, outlined, sectioned, images. Have pencilled in a, recurring, calender item for successful plannning/building control application(s) occurrence - a very well deserved donation for you both ;- ) Nearly ready to start some serious drawing here - after I order the Turkey... |
Current timezone is GMT Sep 20, 2026, 5:01:29 PM |
