Print at Sep 26, 2026, 6:39:51 PM
Posted by Greymagic27 at Jan 28, 2023, 1:02:57 PM
Missing 'something' in custom imported 3D model (texture/triangles?)
I imported a custom 3D model however when I apply the texture the model breaks. See screenshots below:
3D Model: https://sketchfab.com/3d-models/mid-century-m...e17d642b582d0c5ccf9dd64b3
Result: https://imgur.com/a/JJNoqwu
The texture is the correct size so I'm not sure what's causing this. Any pointers would be nice!
Posted by Puybaret at Jan 28, 2023, 6:34:00 PM
Re: Missing 'something' in custom imported 3D model (texture/triangles?)
The 3D model you imported might contain a different material for both sides of each face of the model (the face you see and its opposite face). If it's the case, you could try to make invisible the material of the inner face of your model with the Material modification dialog box.
Posted by Greymagic27 at Jan 28, 2023, 7:35:23 PM
Do you have screenshots or a video guide about how to do this? It's probs very simple (and I will give it a go in the mean time) but screenshots with arrows would help!
Posted by Greymagic27 at Jan 28, 2023, 7:38:41 PM
Edit: I've looked in the material modification box however I can't see anything to make a texture invisible there.
Posted by Greymagic27 at Feb 25, 2023, 5:59:29 PM
Any luck on finding it?
Posted by Puybaret at Feb 25, 2023, 10:32:04 PM
What about the Invisible option shown here?
Posted by Greymagic27 at Feb 25, 2023, 11:11:29 PM
It switches to texture when applying the custom texture
