Print at Sep 23, 2026, 6:05:12 PM
Posted by thomasmendozajr at Jan 21, 2023, 6:54:02 AM
Is there away to change 2D background color?
I was wondering if there was a way to change the background color in the 2d window Od rather use a darker color
Posted by Puybaret at Jan 21, 2023, 11:35:56 AM
Re: Is there away to change 2D background color?
Only by program, by calling setBackground method on the plan component.
Posted by Daniels118 at Jan 21, 2023, 11:40:21 AM
You may import a background image of the color you like. When importing specify a size larger than your home so that it covers the whole plan even if you zoom out.
You have to import the background on each level.
Be aware that a too dark background will reduce the contrast with lines.
Posted by thomasmendozajr at Jan 21, 2023, 3:14:50 PM
Sounds good but how do I call setbackground on plan component? I haven’t messed with a lot of coding in sweethome3d but that would be great so I can set plans for all my foundations plans and layout plans,
Posted by Puybaret at Jan 21, 2023, 6:59:09 PM
If you're able to run Sweet Home 3D from code source, simply change implementation of getBackgroundColor and getForegroundColor in PlanComponent class. Otherwise, this might be difficult.
