Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to create a flat 3D shape/a flat plate, but with more than 4 corners? |
| Print at Sep 26, 2026, 2:36:20 PM | View all posts in this thread on one page |
| Posted by Soulbrother at Jan 17, 2023, 8:32:23 PM |
How to create a flat 3D shape/a flat plate, but with more than 4 corners? Hi, I know how to create a wall and use this as a 3D form (shape). But I would need a more complex shape, easy enough to draw as the ground ("floor-shape of a room"), but I wonder if it would be possible to use a room´s "floor-shape" as a 3D export, to create a 3D shape. Or is there another tool to be able to create a "poly-shape"? Thanks for all hints :-) |
| Posted by Mike53 at Jan 17, 2023, 11:25:03 PM |
Re: How to create a flat 3D shape/a flat plate, but with more than 4 corners? The room tool is the right idea, create it on a level other than ground floor, that way you will be able to set and/or adjust its depth. You can freehand the room or use walls, set at maybe 2mm wide and 2mm high to draw the shape you require. |
Current timezone is GMT Sep 26, 2026, 2:36:20 PM |
