Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How Can I Select Objects Completely Covered-up by Other Objects? |
| Print at Sep 20, 2026, 8:42:29 PM | |
| Posted by DonGib at Jan 13, 2023, 5:39:27 PM |
How Can I Select Objects Completely Covered-up by Other Objects? I have a big box object that is over a smaller box object. I want to select the smaller box to edit its properties without moving the box that is over it to get to it. (I apologize for the simple question. I'm a newbie and I don't have time to read 2,276 post titles to find an answer.) Thanks in advance. |
| Posted by hansmex at Jan 14, 2023, 11:20:41 AM |
Re: How Can I Select Objects Completely Covered-up by Other Objects? - make the big box invisible - delete the small box using CTRL-X - make the big box visible again - paste the small box using CTRL-V H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Daniels118 at Jan 14, 2023, 11:40:17 AM |
Re: How Can I Select Objects Completely Covered-up by Other Objects? If you use the desktop version you can install the Pan 3D view plugin, it allows to select objects by clicking them in the 3D view. Just orient the camera until you see the object and click it. |
| Posted by Puybaret at Jan 14, 2023, 11:58:24 AM |
Re: How Can I Select Objects Completely Covered-up by Other Objects? Right click in the plan or in the 3D view where the item is placed and choose it in the contextual menu. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by DonGib at Jan 14, 2023, 4:18:47 PM |
Re: How Can I Select Objects Completely Covered-up by Other Objects? Nice suggestions. Thank you very much! I don't need to tell you, but I will anyway. Sweet Home 3D is very good. |
Current timezone is GMT Sep 20, 2026, 8:42:29 PM |
