Print at Sep 15, 2026, 7:59:55 AM
Posted by FlaStorm32 at Dec 25, 2022, 5:05:21 PM
confused   Stairs don't reach the wall height
I created a 2-level structure with doors on the second level. 8 foot walls. When I try to add the Exterior Stairs, they do not match the wall height. When I adjust the height, I get huge railings. A straight stair will fit correctly, but I need the landing at the top.
https://postimg.cc/Nyw6wNP5
Thanks!
Posted by FlaStorm32 at Dec 25, 2022, 5:35:32 PM
Re: Stairs don't reach the wall height
I tried the staircase generator, but it doesn't allow for an upper landing. Otherwise, the stair fit well enough.
Posted by kawal at Dec 26, 2022, 7:30:46 AM
I also had the same problem. I made every step of the stair and landing manually using the box. I picked the box, kept the length 36", thread 10" and riser 6" and with different elevation for every stair I built my own and later grouped all together.
Posted by cadilhac at Jan 3, 2023, 6:19:29 PM
The Staircase Generator does have an option for staircase with landing, doesn't it? Tweaking the numbers therein, you can put the landing at the top:
Posted by FlaStorm32 at Jan 4, 2023, 2:13:27 AM
Straight with Landing showed me a Bottom landing, so I passed it up. Will have to work with it more. Thanks!
Posted by MichaelS1950 at Apr 8, 2024, 10:56:26 PM
Hello,
Newbie here. Just bought the software today.
I'm looking for a stair with a landing almost like the picture except with the rail on one side.
My question is where do I find the stair generator? Is it an add on?
Thanks very much.
Posted by Puybaret at Apr 9, 2024, 2:46:36 PM
The Staircase generator is a plug-in available here.
