Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: New way of solving "Repeating GUI item" glitch in Win 10. |
| Print at Sep 28, 2026, 12:51:09 AM | |
| Posted by SarahC_ at Dec 22, 2022, 3:36:34 PM |
New way of solving "Repeating GUI item" glitch in Win 10.2 monitors, Windows 10, NVidia RTX2060, latest drivers as of 2022/12/22.... None of the tweaks worked for me when I was getting menus and GUI elements overlapping each other. Disabling Discord, exiting NVidia Experience, tweaking Config files, installing newer JVM didn't work. (I imagine NVidia Experience MAY work if you've set your "All Programs" setting to override each programs own settings - a bad idea. You should tailer each programs overrides individually to prevent issues just like this one!) What I discovered DID work: 1: Right click the C:\Program Files\Sweet Home 3D\SweetHome3D.exe file. 2: Select the "Compatibility" tab. 3: Run in compatibility for: "Windows 8" None of the tickboxes need be ticked. That's it for me at least! I went through lots of options, run as admin, fullscreen optimisations, Win XP, Vista, Win 8, and discovered the least minimum setting was just Win 8... |
| Posted by Puybaret at Dec 24, 2022, 2:15:00 PM |
Re: New way of solving "Repeating GUI item" glitch in Win 10. I guess you speak about the bug #684. I will post your suggestion in this bug report in the hope it can help other users. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 12:51:09 AM |
