Print at Oct 5, 2026, 9:44:45 PM
Posts: 99   Pages: 10   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Posted by Puybaret at Jan 16, 2023, 6:32:43 PM
Re: Staircase generator plug-in
Special cases can be created by assembling intermediate staircases.
For example, if you need a handrail with brackets along a wall then a handrail with a balluster, you can assemble an intermediate straight staircase, two intermediate square spiral staircases and a simple straight staircase.
Happy New Year to you all smile
Attachment StaircaseWithStorageRoom.sh3d (186509 bytes) (Download count: 773850)
Posted by captaincook at Jan 17, 2023, 5:20:32 PM
Bonjour Emmanuel.
Et bien j'ai suivi vos conseils à la lettre et le résultat est pratiquement identique à mon escalier d'origine.
J'ai simplement recopier la rambarde d'origine sur le nouveau.
Bonne journée et encore un grand merci.
Posted by Keet at Mar 11, 2023, 8:31:08 PM
The staircase generator sets the system PC user as the creator of the generator staircase. This is NOT something you want to happen if you share your created home here on the site.
I suggest that the generator dialog includes a field to set the creator name.
Oh, and the Roof generator does the same. Something for Dorin to fix wink
Posted by Keet at Mar 12, 2023, 12:26:40 PM
Daniels118 found the source of the problem:
HomePieceOfFurniture roofPiece = new HomePieceOfFurniture(new CatalogPieceOfFurniture(null, roofName, null, iconContent, modelContent, size.x, size.z, size.y, 0, true, null, System.getProperty("user.name"), true, null, null));
(In the roof generator thread: https://sweethome3d.com/support/forum/viewthread_thread,11330_offset,150#57817 )
Dorin tested with replacing the value with null which worked and will be avialable in the next update.
Maybe the same solution could be used for the roof generator.
Posted by Puybaret at Mar 12, 2023, 11:19:25 PM
I consider that when you want to share a model, you prefer to have some kind of credit.
If you fear your login may be disclosed, just edit the OBJ file and replace your login by whatever you want.
Posted by Keet at Mar 13, 2023, 9:10:15 AM
Sorry, but I see that the other way around: never disclose a login name, it's a security leak. In many cases it will not be the name you want to use to get credit with anyway. If I want credit under a specific name I can edit the object file to insert that name but I don't want to edit EVERY object I want to share, and again with updates.
My username is different on PC and laptop and none are 'Keet', the name I would use to get credit for a shared object. Similar situations will go for most users I believe.
To explain the severity of the problem besides it being a security leak: For several years now I am creating dozens of different houses for a valley/island with most of the furniture, doors, windows, etc. custom made. This problem means I will have to edit every single house. When I have shared the projects (in a year or two) I will have to do all of that again every time I have updated houses and share again.
I'm a software developer. I can create a script or program to run over all houses and do the editing but most other users will not be capable to correct something that the software shouldn't have done in the first place. It's also easy to forget such a last run over the projects before sharing.
If I ever disclosed usernames in software output I would be out of business, please change this to something else. The most perfect way would be to have a preference setting where you can set a name for credit in exports but anything other than a login name would do. Changing 'System.getProperty("user.name")' to '"creator"' is probably the easiest bug fix you have ever done smile
Posted by Puybaret at Mar 13, 2023, 5:09:54 PM
As some other plug-ins may use this way of doing and you don’t want it, you could try to set the user.name property to another value with the Java option -Duser.name=myname (this option can be set using the same way as the -Xmx option used to increase memory and explained in the FAQ).
This should fix this way of doing that you consider as a security leak.
Posted by Keet at Mar 13, 2023, 7:09:29 PM
That works! (Although I'm still of the opinion that it's a serious security leak that should not have been introduced in the first place.)
I also found a second way around this which might be usefull for other users: Use the furniture library editor for every single object you create where you can set the creator name for each object. Once you add furniture in your plan that is imported through a furniture library the name is used as set in the library. This also allowes to use multiple different creator names if you wish to do so.
Posted by Tungmeister at Jul 29, 2023, 11:34:43 AM
I might provide a longer list of materials in a coming version since some of you think it's really necessary. I'll update the translation at that moment.
Could you share how to set randomized coordinates for the textures as you did for the threads and risers?
Source code is included in the plug-in so you can have a look by yourself. It's just a random offset added to x and y texture coordinates, a different offset being drawn for each tread and riser...
Could you help me remove the random values please? My stairs have a stair runner on them so I need the texture to be uniform across all the steps. I downloaded the source and replaced the random values with 0s however after compiling and adding the plugin sweethome just hangs on the splash screen and I can't work out what I'm doing wrong.
Posted by Puybaret at Jul 29, 2023, 8:47:31 PM
Did you compile the plug-in with Java 8 or options to generate Java bytecode compatible with Java 8 (or Java 11 or 15 if you use Sweet Home 3D with those versions)?
You could also create the stair runner with a smaller staircase without stringers and handrails. Just elevate it a bit to make it appear on top of the stairs of the main staircase, like in the following example.
