Print at Sep 15, 2026, 7:05:14 AM
Posted by lgradassi at Dec 13, 2022, 2:13:09 AM
File opening but not showing on screen
Hello,
I cannot open a file anymore. I've no error when I open it, but nothing shows up. If I tries to re-open it, I've an error that the file is already open.
Can somebody help me ? I can send you the file if it helps.
A weird behavior. If I open SH3D by double clicking on a sh3d file, the process goes under the app group in task manager and the application show up. If I do the same with my other file (the one I cannot open) the process is launched, but it stay on Background Processes, and the app doesn't show in windows.
I'm using 7.0.2 version (was 7.0.0 last time a save this damn file)
Posted by Puybaret at Dec 13, 2022, 9:27:23 AM
Re: File opening but not showing on screen
Send me your file, I'll try to fix it.
Posted by Puybaret at Dec 13, 2022, 12:08:35 PM
I just tried the file you sent and didn't have any problem to open it and view it under Windows and macOS. Maybe it's an access right not granted to the file in the operating system.
What operating system do you use?
Posted by lgradassi at Dec 13, 2022, 1:49:21 PM
I'm on windows 10. Maybe it is an issue with some plug-in. I'll try to remove all plug-ins and see what happens. Is there some way to launch SH3D in verbose mode to generate some logs ?
Posted by lgradassi at Dec 13, 2022, 1:51:09 PM
ok, i'm able to open it if I remove all the plug-ins. I'll try to reinstall the plug-ins one by one and see which one fails.
Posted by lgradassi at Dec 13, 2022, 1:53:53 PM
seems to be the wiring plug-in that fails....
thank you for you help
Posted by Daniels118 at Dec 13, 2022, 5:23:35 PM
If you can share the file I will try to find the bug affecting the Wirings plugin.
