Print at Sep 20, 2026, 9:16:55 PM
Posted by GaudiGalopin3324 at Dec 11, 2022, 6:26:38 PM
confused   how to practice spiritualism using SH3D? There are serious problems..
Hi everybody. I tried to create a magical mirror corridor to communicate with ghosts. But no! On the third cycle of reflections, the program gives a failure ((. Two cycles of reflections are not enough. For a session of spiritualism, you need a lot more cycles, otherwise the ghost does not come. Is there a solution to this serious problem? For example: A mirrored door opposite the mirror above the sink. And a black square appears.. Help.
https://disk.yandex.ru/i/2kRmSnBNLpVavA
Posted by GaudiGalopin3324 at Dec 12, 2022, 7:48:13 PM
Re: how to practice spiritualism using SH3D? There are serious problems..
I'm disappointed. Where there are two, there are three... Why is there a limit of reflections in the mirror for two cycles? Why spare the processor? As a result, no communication with interesting personalities from the past ((
Posted by Puybaret at Dec 12, 2022, 9:19:47 PM
Sorry for the bad communication, but reflections must be limited to avoid infinite computing!
If you're a programmer, you may increase the number of reflections with SunFlow renderer by modifying the parameter set in PhotoRenderer class but from the tests I made you can't use a very large value. With YafaRay renderer, I don't know.
Posted by dorin at Dec 12, 2022, 9:32:59 PM
Be careful what you wish for! It might come true.
It is a door through which an angry Ukrainian could enter.
Then you will really cry for help.
This tread will be moderated.
Posted by GaudiGalopin3324 at Dec 12, 2022, 11:24:35 PM
unfortunately I'm not a programmer. But if the program had at least 10 reflection cycles, the processor would not overheat. Maybe. But a picture would be acceptable. It's a pity. Okay, I will avoid such angles. In any case, thanks for the advice!
Posted by GaudiGalopin3324 at Dec 12, 2022, 11:33:15 PM
you have very kind eyes in your avatar. I wish you peace and happiness. Don't worry about me. We're trying to deal with mirrors, nothing more.
