Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: how to practice spiritualism using SH3D? There are serious problems.. |
| Print at Sep 20, 2026, 8:42:53 PM | View all posts in this thread on one page |
| Posted by GaudiGalopin3324 at Dec 11, 2022, 6:26:38 PM |
how to practice spiritualism using SH3D? There are serious problems..Hi everybody. I tried to create a magical mirror corridor to communicate with ghosts. But no! On the third cycle of reflections, the program gives a failure ((. Two cycles of reflections are not enough. For a session of spiritualism, you need a lot more cycles, otherwise the ghost does not come. Is there a solution to this serious problem? For example: A mirrored door opposite the mirror above the sink. And a black square appears.. Help. https://disk.yandex.ru/i/2kRmSnBNLpVavA |
| Posted by GaudiGalopin3324 at Dec 12, 2022, 7:48:13 PM |
Re: how to practice spiritualism using SH3D? There are serious problems.. I'm disappointed. Where there are two, there are three... Why is there a limit of reflections in the mirror for two cycles? Why spare the processor? As a result, no communication with interesting personalities from the past (( |
| Posted by Puybaret at Dec 12, 2022, 9:19:47 PM |
Re: how to practice spiritualism using SH3D? There are serious problems.. Sorry for the bad communication, but reflections must be limited to avoid infinite computing! If you're a programmer, you may increase the number of reflections with SunFlow renderer by modifying the parameter set in PhotoRenderer class but from the tests I made you can't use a very large value. With YafaRay renderer, I don't know. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dorin at Dec 12, 2022, 9:32:59 PM |
Re: how to practice spiritualism using SH3D? There are serious problems.. Be careful what you wish for! It might come true. And a black square appears.. Help. It is a door through which an angry Ukrainian could enter. Then you will really cry for help. This tread will be moderated. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by GaudiGalopin3324 at Dec 12, 2022, 11:24:35 PM |
Re: how to practice spiritualism using SH3D? There are serious problems.. unfortunately I'm not a programmer. But if the program had at least 10 reflection cycles, the processor would not overheat. Maybe. But a picture would be acceptable. It's a pity. Okay, I will avoid such angles. In any case, thanks for the advice! |
| Posted by GaudiGalopin3324 at Dec 12, 2022, 11:33:15 PM |
Re: how to practice spiritualism using SH3D? There are serious problems.. Be careful what you wish for! It might come true. . you have very kind eyes in your avatar. I wish you peace and happiness. Don't worry about me. We're trying to deal with mirrors, nothing more. |
Current timezone is GMT Sep 20, 2026, 8:42:53 PM |
