Print at Sep 15, 2026, 3:11:17 AM View all posts in this thread on one page
Posted by KitchM at Dec 6, 2022, 10:06:00 PM
What Is Magnetism
Is magnetism the same as snap-to? It sure looks that way from the video tutorial.
Posted by Puybaret at Dec 6, 2022, 10:17:59 PM
Re: What Is Magnetism
Magnetism doesn't snap to the grid. Otherwise, please search for magnetism in the help, it's cited in many pages!
Posted by KitchM at Dec 7, 2022, 6:01:21 PM
Yes, you are correct that the word shows up multiple times. However, it is not defined in its function nor in relationship to snapping to a grid; which is a reasonable expectation. The novel way it is used in the program dictates a need for a definition.
Posted by Keet at Dec 7, 2022, 6:53:49 PM
Magnetism is between objects. Snap-to-grid is not magnetism, but as you stated yourself, snapping to the grid smile
I'm not aware of any program where snap-to-grid is called magnetism.
Posted by KitchM at Dec 7, 2022, 7:58:00 PM
So the use of "magnetism" in this program is where one object is attracted to another.
Can you explain the use of such a feature? Is it like a chair to a table, or is it like the end of one line to the end of another?
Posted by Keet at Dec 7, 2022, 10:33:54 PM
The most common occurance is where doors and windows slip into a wall and adjust themselves to the wall thickness.
If you drag furniture against a wall it sticks and orientates against the wall so you don't have to manually fit it against the wall.
Objects can also be dragged against each other and have a magnetism point where they 'stick' together, also for easy placement.
Magnetism also causes furniture rotation and wall angles to occur in steps of 15°.
If you switch magnetism off you can set any angle, place doors and windows without deforming into a wall, and move objects over each other without sticking against each other. This is all with mouse movement. When using the arrow keys magnetism is ignored.
Posted by KitchM at Dec 7, 2022, 11:24:47 PM
Thank you for the good info and explanation. This makes it easier for all.
Posted by JessieJim at Dec 14, 2022, 5:31:52 AM
Yes thanks for explanation!
